Go to Post New mentor joins one team and ends up impacting several in the same region. I like that. :) - Travis Hoffman [more]
Unread 11-02-2014, 01:19
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Alternatives to the Cypress IO
Is the Cypress PSoC board the only one compatible with the Driver Station I/O feature, or can an Arduino/Beaglebone be used to interface with the DS I/O?
Our Cypress board has broken and I can't seem to find another source for a replacement. I do have an arduino lying around and can use it if possible, but I doubt it's compatible with the FRC-provided firmware.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 11-02-2014, 01:32
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Alternatives to the Cypress IO
Texas Instruments has a HID Joystick boosterpack for the Tiva Launchpad. It enumerates as two joysticks and has a breakout for all axis/buttons.
http://www.chiefdelphi.com/forums/sh...d.php?t=122587
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 11-02-2014, 01:38
I've never seen the Cypress protocol published.
You can program the arduino to look like a joystick, if you don't need 4 joysticks. If you want something off the shelf, you can get a Estop Robotics CCI
Unread 11-02-2014, 08:15
Here is the Cypress firmware source if you want to investigate the protocol.
File Type: zip Driver_Station_I_O_Firmware_Source_v2.zip (39.7 KB, 55 views)
Unread 11-02-2014, 08:20
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
while not a replacement for the Cypress, there are more ways to interface arbitrary stuff as a 'joystick': http://www.ultimarc.com/ipac1.html (we used this last year for a custom control panel: our Cypress is long lost!)
Another possibility: a 'joystick' that is software defined and can be actuated by other software running on the PC. http://vjoystick.sourceforge.net/site/. Haven't used it for competition, but have used for testing...
Unread 11-02-2014, 15:43
parkedraccoon's Avatar
parkedraccoon parkedraccoon is offline
FRC #0766
Team Role: Electrical
parkedraccoon is on a distinguished road
If you want to use your Arduino, we have used UnoJoy with success. It appears to the computer as a regular joystick and so shows up in Driver Station and is compatible.
"Why is it stupid?"
2006-2008 Little brother of Team 766 member
2008 FLL
2009-2014 FRC 766
2014-> ??? (hopefully some sort of mentor!)
Unread 12-02-2014, 17:02
seg9585's Avatar
AKA: Eric
Thanks everyone. I can try some of the controller-based solutions. Does anyone know who still sells these Cypress boards? They were on FIRST Choice but it appears Cypress has stopped selling them completely.
My FIRST legacy:
Unread 16-02-2014, 09:43
VEI Dude's Avatar
VEI Dude VEI Dude is offline
Mentor 4024, 4013
AKA: Neil the Real Deal
FRC #4013 (Jokers & Clockwork Mania)
VEI Dude has a spectacular aura aboutVEI Dude has a spectacular aura about
Last year when I was with 4024, we had issues with the Cypress I/O and could not get support for it. So we hacked the control board out of a Logitech joystick, traced the switch wiring, and made our own control panel which looked like a joystick on the drivers station.
ID:	16252  Click image for larger version
ID:	16253  Click image for larger version
ID:	16254  Click image for larger version
Unread 01-03-2014, 10:09
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
The Cypress board has been discontinued by Cypress Semiconconductor. Unfortunately, there doesn't appear to be a follow-on device for output. But, there are lots of alternatives for inputs including the CCI board from EStop Robotics and the TI Launchpad board from Texas Instruments. Additionally, the Arduino Leonardo also has a mode that makes it behave as a Joystick. I'm just hoping that the 2015 control system gets a way to drive digital outputs at the driver station so we can drive status LEDs for the drivers. Those are much more visible than a virtual LED on the SmartDashboard.
HTH,
Mike
