Go to Post We don't require innovation; we simply encourage it. - Tristan Lall [more]
Unread 11-02-2014, 16:08
Animal Control's Avatar
Animal Control Animal Control is offline
FRC #2345
Animal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these parts
Exclamation pneumatic cylinders and motors with wires
if you have motors outside the frame how do you have to hold the wires and how must the pneumatic pistons be attached?
Unread 11-02-2014, 16:11
Oblarg Oblarg is online now
AKA: Eli Barnett
Re: pneumatic cylinders and motors with wires
Could you please be a bit more specific? It's completely unclear what exactly you're asking.
"The breakfast of champions!"
Unread 11-02-2014, 16:16
FRC #2345
will have to send to you through you'r email. my computer will not let me put the picture up
Unread 11-02-2014, 16:18
AKA: Eli Barnett
Upload it to imgur.com, copy-paste the image URL and use the [IMG] tags. Ensure that the link inside the BBCode ends with .jpg (i.e., that it's the image location and not just the imgur page).
Unread 11-02-2014, 16:19
FRC #2345
but the image is from my camera
Unread 11-02-2014, 16:20
AKA: Eli Barnett
If you can put it in an email, you can put it on imgur.
Also, in the future, you should post this sort of thread in the technical discussion forum, not the general forum.
FRC #2345
https://mail.google.com/mail/u/0/?ui...0&disp=safe&zw
I think I got the arm hanging and the pneumatic
Unread 11-02-2014, 16:27
While a picture is certainly likely to help us understand what you're asking, a few more words might be useful in the meantime.
What does "outside the frame" mean when you say it?
What is the function of the motors you are asking about?
To what are you trying to attach the pneumatic "pistons"? Do you mean pneumatic cylinders, or are you trying to refer specifically to the end of the moving rod?
Unread 11-02-2014, 16:30
FRC #2345
Where the blocks are is where the bumpers will be
The motor turn to pick up the ball
The pistons are used to pick up the arm with the ball and lower the arms to get the ball
Unread 11-02-2014, 16:35
Um...yeah, go ahead and try to upload a picture somewhere we can see it. Your Gmail link won't work for anyone who isn't logged on to your Gmail account.
Unread 11-02-2014, 16:42
FRC #2345
Unread 11-02-2014, 16:48
AKA: Eli Barnett
I would be cautious about that motor placement, but for running the wires I'd recommend the usual judicious use of zipties.
For attaching the pistons, at the rod-end you'll probably do best to use a standard bimba rod-end clevis, and at the rear end you'll either want their pivot brackets or you'll want to push out the pin that comes standard (by means of a large bench vise - I've tried a two ton arbor press to no avail) and use a bolt.
Unread 11-02-2014, 16:49
FRC #2345
thank you
Unread 11-02-2014, 16:53
I don't think there are any specific rules that require you to attach your wiring in any particular way. If that ball pickup assembly starts the match inside the frame perimeter, then you can do it pretty much however you see fit.
You'll want to make sure they don't pose an entanglement risk to other robots, and that they aren't prone to being pulled out or tugging on (and breaking) the motor's electrical terminals. It might even be a good idea to include some sort of guard around the motor itself to keep it from accidental damage.
I still don't understand what you want to know about mounting the pneumatic components.
Unread 11-02-2014, 16:57
mott's Avatar
mott mott is offline
AKA: Mike Ott
FRC #1619 (Up-A-Creek Robotics)
mott is on a distinguished road
If I'm seeing this correctly, it appears this is a ball collector hanging outside the front frame perimeter (when deployed).
In addition to the high risk of your wires being caught and ripped off the machine, I'd venture to say your actual gear motor assembly might not last through more than a couple matches before getting destroyed in a side-impact collision with an aggressive defender.
I'd strongly suggest some additional protection for your mechanism and the attached wiring.
