Go to Post if you put 3 controls engineers in a room you will get 4 different way to do tuning. - FrankJ [more]
Unread 11-02-2014, 16:27
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Administrative and Game Manual updates - 2/11
Administrative Manual
Section 5.4.3: Robot Displays
New this year! To assist teams with their promotional and community relations activities, robots may be unbagged and operated briefly after “Stop Build Day” for display purposes only.
  • The intent of this option is to allow teams to briefly show their robot to their community, sponsors, or potential sponsors after “Stop Build Day”.
  • Unbagging a robot and putting it on display for many hours (i.e. more than four (4)) at a time would not be considered a ‘brief’ display
  • The Robot Lock-Up Form must be used to track the unbagging and rebagging of the robot during this period. In the ‘Explanation’ column of the form, enter ‘Robot Display’
  • No activity that could be considered ‘work on’ or ‘practice with’ the robot is allowed
  • Brief displays of robot functions – driving, for example - are allowed, but not to the extent that they could be considered practice
  • A good way to avoid turning a robot display period in to a practice session is to have non-drive team members operate the robot, and only for as short a time as necessary to show the robot’s capabilities
If you have any questions about this new Robot Display option, please email frcteams@usfirst.org
Section 5.6.2: ‘Robot Access Period’ – Schedule
Teams may unlock their robot for a total of 6 hours during the 7-day period preceding any two-day event in which their team will be competing with their robot. The 6 hours may be broken up in any way the team wishes, with the exceptions that no single access period may be shorter than 2 hours 30 minutes and the team may not have more than 3 access periods prior to each event. The robot must be locked up in between sessions and this must be documented on the Robot Lock-Up Form each time.
Game Manual
The original intent of the 45 lb FABRICATED ITEMS allowance granted to Teams via R18 was to allow Teams the opportunity to keep a part of their ROBOT out of the bag for further development. However, because of the definition of ROBOT and the term’s use in R15, Teams were not allowed to keep a required ROBOT system (e.g. mobility, control, etc.) out of the bag. R15 and R18 have been updated to better capture the original intent.
Question 219 in the Q&A asked if Teams could use soft material to secure the pool noodles to the wood during fabrication of the BUMPERS. Since that answer has been posted, we have received feedback from many Lead Robot Inspectors regarding their concern for consistent rulings during Inspections across multiple events. Because of this, we have edited R21-C, D, and E to allow fasteners to be used in this manner so long as the general cross section (Figure 4-8) of the BUMPER is not altered. The answer to Q219 has been updated.
Section 3.1.4: Scoring
A CYCLE is the series of events that recur regularly in TELEOP, and each CYCLE begins with an ALLIANCE member retrieving their BALL from their lit PEDESTAL and ends when the BALL is SCORED in a GOAL.
Section 4.3: Budget Constraints
R11
No individual, non-KOP item shall have a value that exceeds $400 USD. The total cost of COMPONENTS purchased in bulk may exceed $400 as long as the cost of an individual COMPONENT does not exceed $400.
Section 4.4: Fabrication Schedule
R14
All [strike]The ROBOT elements, with the exception of those withheld per R18 (including items intended for use during the competition in alternative configurations of the ROBOT, excluding items permitted per R18), must be bagged or crated (as appropriate for your event), and out of Team hands by the end of Stop Build Day, February 18, 2014 (refer to the FRC Administrative Manual, Section 5 for more details).
R15
Teams must stay “hands-off” their bagged ROBOT elements during the following time periods:
from Stop Build Day until their first event,
during the period(s) between their events, and
outside of Pit hours while attending events.
Modifying parts at night offsite (e.g. pits have closed and you bring a MECHANISM back to the hotel to fix it) is a violation of R15-C.
Additional time is allowed as follows:
There are no restrictions on when software may be developed.
On days a team is not attending an event, they may continue development of any items permitted per R18, including items listed as exempt from R18, but must do so without interfacing with the ROBOT bagged ROBOT elements.
Teams attending 2-day events may access their bagged ROBOT elements ROBOTS per the rules defined in the Administrative Manual, Section 5.6, ROBOT Access Period - for Teams Attending 2-Day Events.
ROBOTS may be exhibited per Administrative Manual Section 5.4.3: Robot Displays.
Section 4.5: Material Utilization
R18
At an Event, Teams may have access to a static set of FABRICATED ITEMS that shall not exceed 45 lbs to repair and/or upgrade their ROBOT. Items made at an Event do not count towards this weight limit.
Section 4.6: BUMPER Rules
R21
BUMPERS must be constructed as follows (see Figure 4-8):
use a stacked pair of approximately 2 ½ in. round, petal, or hex “pool noodles” (solid or hollow) as the BUMPER cushion material (see Figure 4-8). Cushion material may extend up to 2 ½ in. beyond the end of the plywood (see Figure 4-5 and Figure 4-9). To assist in applying the fabric covering, fasteners may be used to attach the pool noodles to the wood backing, so long as the cross section in Figure 4-8 is not significantly altered (e.g. tape compressing the pool noodles)
be covered with a rugged, smooth cloth (two layers of cloth is permitted if needed to accommodate R27, provided the cross section in Figure 4-8 is not significantly altered).
Optionally, use aluminum angle to clamp cloth, as shown in Figure 4-8, or other fasteners (e.g. staples, screws, etc.) to clamp cloth.
Clamping bumpers and altered robot access.
Unread 11-02-2014, 16:38
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Administrative and Game Manual updates - 2/11
The change to the minimum access period time is not something I expected. Does anyone know the reason behind it (even though it probably won't change our behavior)?
Unread 11-02-2014, 16:39
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
That's interesting. I like the change, but I wonder why they did it now?
Unread 11-02-2014, 16:40
mikemat mikemat is offline
mikemat has a spectacular aura aboutmikemat has a spectacular aura aboutmikemat has a spectacular aura about
I assume it's because if you used 2 hours your first time and 2:01 your second, you just wasted your last 1:59 under the old rules. The new ones give a bit more leeway.
Oblarg Oblarg is offline
AKA: Eli Barnett
I am currently reading "fasteners are allowed to attach the pool noodles to the backing..." as "you can use tape as long as you're not compressing the bumpers with it." Or does tape not qualify as a fastener? Thoughts?
"The breakfast of champions!"
Unread 11-02-2014, 16:43
Given the answer to Q219, tape IS legal (so long as you don't stupidly compress the noodle).
Unread 11-02-2014, 16:45
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I agree this is likely the reasoning. Last year for the MN State tournament (in May) we used the District unbagging rules between a teams last event (regional or champs) and States, and I had this discussion with several teams. It really sucks to lose that time because of a minimum unbag period allowance.
The way I read it, this ruling allows tape. Specifically, the update to R21, which includes "Tape" in the description: "To assist in applying the fabric covering, fasteners may be used to attach the pool noodles to the wood backing, so long as the cross section in Figure 4-8 is not significantly altered (e.g. tape compressing the pool noodles)"
2016: Lake Superior WFFA
FF TSL: Frog Farce
But why change it now?
Unread 11-02-2014, 16:49
AKA: Eli Barnett
Thank you.
Unread 11-02-2014, 16:54
I have no clue. Maybe someone finally brought it to their attention, maybe they thought it would encourage teams to be more honest with their unbag time.
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Because FIRST felt it was a good idea/change to make?
Unread 11-02-2014, 18:23
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Better late than never.
I am very happy with this team update. Lots of good stuff. They really payed attention the feedback from the community, and made some good, reasonable changes because of it.
11 team updates so far and they have yet to make many people angry. Things are looking good.
Unread 11-02-2014, 18:38
GaryVoshol's Avatar
Cogito ergo arbitro
Would you rather they changed it after Week 1?
I'm guessing they changed it now for the same reason that there are so many bumper questions here on CD lately - because it's what people are starting to think about.
(since 2004)
Unread 13-02-2014, 14:35
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
I think this new rule with respect to demonstrations violates FIRST's own "third party observer" rule. How would you explain it to your grandmother that you can't keep working on or testing the robot because it's beyond "stop build day" and in its bag...... Then you turn around and unbag it to drive it around. I miss the days when a FedEx truck would show up and take the robot away from you. Much less chance for teams to pull post-stop-build-day shenanigans.
Seems like FIRST is getting easier and easier every year. All you really need to do this year is pick-up and throw a ball- half of the robot pictures I've seen on CD here look identical. The only real part of the robot being built anymore is the frame which holds all the COTS items together and even those can be purchased "off the shelf". (Veterans- remember trying to mount drill motors? Or having a 20000RPM motor with no clue how to use it?) Between the number of COTS items available from awesome vendors like AM and VEX, three different groups posting videos and instructions within the 1st week on "how to build your aerial ascent robot", the ever-increasing withholding allowances, being allowed to unbag in order to drive your machine around... Yes it is his 10th demonstration this week but no no grandma- I assure you our driver isn't getting any experience. Anyone know where to get more lockup tags?
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 13-02-2014, 14:38
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Originally Posted by fox46 View Post
[IMG]
Seems like FIRST is getting easier and easier every year. All you really need to do this year is pick-up and throw a ball- half of the robot pictures I've seen on CD here look identical. The only real part of the robot being built anymore is the frame which holds all the COTS items together and even those can be purchased "off the shelf". (Veterans- remember trying to mount drill motors?) Between the number of COTS items available from awesome vendors like AM and VEX, three different groups posting videos and instructions within the 1st week on "how to build your aerial ascent robot", the ever-increasing withholding allowances, being allowed to unbag in order to drive your machine around... Yes it is his 10th demonstration this week but no no grandma- I assure you our driver isn't getting any experience. Anyone know where to get more lockup tags?
This will probably just turn into another one of those debates, but, as far as I'm concerned as long as people are still Inspired by Science and Engineering as a result of FIRST they're still fulfilling their goals, regardless of how difficult the competition itself is to compete and be competitive in.
