Go to Post This only gets awkward when the girl knows more digits of pi than you do... - Walter Deitzler [more]
Unread 11-02-2014, 19:11
RoboNerd01's Avatar
RoboNerd01 RoboNerd01 is offline
Super User
AKA: Austin Rowe
FRC #3604 (Goon Squad)
RoboNerd01 is an unknown quantity at this point
Angry Digital input lag!
I've been trying to use a hall effect sensor and a magnet to measure pulsed from a spinning wheel. But the cRio seems to not respond fast enough to pick up all the pulses. I started clean, and still the problem remains. Has anyone else had this problem? I need help.
Unread 11-02-2014, 19:36
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
calcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nice
Re: Digital input lag!
Rather than using a DigitalInput, I recommend using a Counter instead. It counts up all of the pulses coming from a DIO for you in the FPGA.
In C++, the RPM can be found with "60.0/GetPeriod()" where GetPeriod() is a function in the Counter class which returns the time between pulses in seconds. If there is more than one pulse per revolution, you would use "60.0/(pulsesPerRev * GetPeriod())".
That's the general idea, but the implementation varies depending on which language you are using.
Unread 11-02-2014, 19:57
Jared's Avatar
Jared Jared is offline
The problem is that your robot code loop runs a lot slower (20 ms) than your sensor is sending the signal. The FPGA can sample way faster than that (> 10,000 pules per second), and can be accessed by using a counter and calling the counter.getPeriod() method to get the time between pulses.
If you're planning to use this rpm for some type of control loop, you may notice that the reported speed seems to fluctuate. If this happens you can make the FPGA average the last couple of samples to get a better reading.
