Go to Post Playing fields outdoors in the snow and the only field faults were when you ran out of gas!...ahh the old days - ExTexan [more]
Unread 09-02-2014, 19:48
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
SFX (SmartDashboard 2.0) Exception when loading a save from older build
We spent a bit of time creating a large SFX layout. However, now that we have the newest build of SFX, we hit problems when loading that file (it is attached to this post).
Also, we no longer have a tab called LiveWindow. Was that functionality removed, or this another error behavior?
The exception and SFX layout are attached.
Worst case, we'll just redo the entire layout in the new version... but we'd like to avoid that if possible. =]
Unread 10-02-2014, 19:37
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: SFX (SmartDashboard 2.0) Exception when loading a save from older build
Nope, sounds like an upgrade problem. Files created since middle of december are still valid. Clear out the sfx folder and re-download and unzip it. The LiveWindow tab is created by the LiveWindow plugin, which should be found under sfx/plugins/some.jar If its missing, something went wrong with your installation
Watchdog.Kill();
Unread 11-02-2014, 21:20
FRC #0488
Before we had downloaded just the .jar... your fix of downloading everything worked quite well! Thanks for the help!
