Go to Post When I encounter Dave at competitions and meetings, I find him to be kind, helpful, almost too nice. When I read his hints, I find him to be EVIL! - Ken Loyd [more]
Unread 29-01-2014, 20:26
Zman1311 Zman1311 is offline
None #2876
Zman1311 is an unknown quantity at this point
Unhappy Help in Driving Straight
Greetings,
Our robot does not drive straight with the current code we have. We are using different methods to make it drive straight with encoders and gyros. However, these methods are causing it to veer to one side.
public class AutonomousDrive extends CommandBase {
    double left = .5;
    double right = .475;
    public AutonomousDrive() {
        requires(driveTrain);
        // Use requires() here to declare subsystem dependencies
        // eg. requires(chassis);
    // Called just before this Command runs the first time
    protected void initialize() {
        driveTrain.resetEncoder();
        driveTrain.gyro.reset();
    // Called repeatedly when this Command is scheduled to run
    protected void execute() {
        driveTrain.driveXboxTank(left, right);
        double rightEncoderCompensation = driveTrain.leftEncoder.getDistance() - driveTrain.rightEncoder.getDistance();
        double increaseFactor = rightEncoderCompensation/200.0;
        if (rightEncoderCompensation > 0)
            if (right >= 0.5) {
                left -= increaseFactor;
            } else {
                right += increaseFactor;
        } else if (rightEncoderCompensation < 0) {
            if (left >= 0.5) {
                right -= increaseFactor;
            } else {
                left += increaseFactor;
        /*if (driveTrain.gyro.getAngle() > 0.5) {
            if (right == 1.0) {
                left -= .0025;
            } else {
                right += .0025;
        } else if (driveTrain.gyro.getAngle() < -0.5) {
            if (left == 1.0) {
                right -= .0025;
            } else {
                left += .0025;
We were thinking maybe PID is the solution, but we have no idea on how to implement it.
Unread 29-01-2014, 20:49
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: Help in Driving Straight
How severely does it veer to one side?
Does it always veer to the same side?
What are the units of the getDistance methods? There would be a big difference between adjusting your turn if one wheel was ahead of the other by 0.5 feet vs 0.5 inches.
How did you pick your increaseFactor to divide the distance error by 200?
If the increaseFactor is too small your system will not respond quickly enough to compensate for deviations off your desired heading.
For reference, last year our drive straight code would compensate if we were +/- 1 degree off our heading. Our slow wheel's commanded value would be increased by 10%. this yielded good results on our robot at speeds that were pretty close to our top travel speeds.
http://team2168.org
Last edited by otherguy : 29-01-2014 at 21:23. Reason: changed response, didn't see you were using two encoders in the code block, makes more sense now
Unread 11-02-2014, 21:48
stefanp stefanp is offline
AKA: Stefan Pleava
FRC #4946 (The Alpha Dogs)
stefanp will become famous soon enough
Originally Posted by Zman1311 View Post
Greetings,
    double left = .5;
            if (right >= 0.5) {
            } else {
            if (left >= 0.5) {
            } else {
            if (right == 1.0) {
                left -= .0025;
            } else {
                right += .0025;
            if (left == 1.0) {
                right -= .0025;
            } else {
                left += .0025;
Have you calibrated your talons? We figured this out one meeting when we were having problems going straight.
Unread 11-02-2014, 21:52
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
2 problems our team found:
As mentioned before, calibrate your talons (if that's what you're using).
Second, make sure the bearings flanges inside of your gearbox is in the right orientation, so they're not grinding together, slowing one side down.
Unread 11-02-2014, 23:08
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
[emphasis added by me] THIS. Our robot could hardy even move when we first drove it (a few days ago :P ). We implemented a crude feedback loop to correct for it using the gyro (which worked fairly well), but we later disassembled the gearboxes to find out the problem. We checked our individual wheel speed and two of them were severely off. It turns out that two of our four gearboxes had the bearings improperly installed, causing them not to function properly. From what I heard, it was really difficult to spot, and was only found out when attempting to disassemble and reassemble the entire thing (meaning it wasn't blatantly obvious, regardless of whether or not the gearbox was assembled).
Unread 13-02-2014, 09:20
jls667 jls667 is offline
None #2579
jls667 is an unknown quantity at this point
How do you calibrate a Talon?
Unread 13-02-2014, 09:31
The Talon manual is located on the crosstheroadelectronics.com website, and it explains the calibration procedure in detail.
Unread 13-02-2014, 12:00
None #2579
The calibration sounds easy. Thank you.
