Go to Post "Trying to teach a nerd to be sensitive to girls is like trying to teach a dog Jamacian, and expect it to talk back" - Hansen302 [more]
Unread 11-02-2014, 22:00
ShaneKent253 ShaneKent253 is offline
FRC #0253
ShaneKent253 is an unknown quantity at this point
Programming Double Solenoids
Hello from team 253,
How do you program double solenoids. Please answer with some example code.
Thank You!
Shane
Unread 11-02-2014, 22:37
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: Programming Double Solenoids
The DoubleSolenoid class is pretty easy to work with:
// Create a double solenoid with the forward channel in port 1 and the reverse
// channel in port 2
DoubleSolenoid solenoid = new DoubleSolenoid(1, 2);
// Setting values
solenoid.set(DoubleSolenoid.Value.kForward);   // Set the solenoid to forward
solenoid.set(DoubleSolenoid.Value.kReverse);   // Set the solenoid to reverse
solenoid.set(DoubleSolenoid.Value.kOff);       // Turn off the solenoid
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
