Go to Post All the same lessons that can be learned or taught with custom drive trains can also be learned or taught with custom manipulators and scoring mechanisms, and the latter is far more likely to set your team apart in the competition. - Jared Russell [more]
Unread 11-02-2014, 21:19
rdoglivin rdoglivin is offline
FRC #4976
rdoglivin is an unknown quantity at this point
analog input on the cRIO, can it handle voltage?
Hi i'm on a rookie team and are having trouble finding this answer. Can a 9403 analog input on a cRIO, get voltage and/or ground digital inputs? Any answers or reply's would be helpful at this point. Thanks!
Unread 11-02-2014, 22:26
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Re: analog input on the cRIO, can it handle voltage?
You mean the 9201? Yes, that module can read voltage input, and ground too, though ground may be a little boring.
Unread 11-02-2014, 22:29
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Could you elaborate as to what your goals of reading voltage and grounds are for?
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 11-02-2014, 22:32
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
With all due respect, your question does not make sense. The 9403 takes a voltage input. If the voltage is over a certain threshold (2.7VDC I believe) you read a '1'. If the voltage is under a certain threshold (0.7VDC I think) you read a '0'. The 9403 has 32 such channels that can input or output voltage. In practice the channels are dedicated to specific purposes (PWM, Digital I/O, Relay I/O, I2C etc).
Do you want to input an analog voltage and determine the absolute value? The 9201 module has 8 channels of analog inputs (1 is taken up by the battery measurement).
There are manuals for the devices on the breakout modules online at http://www.usfirst.org/roboticsprogr...control-system .
HTH
