Go to Post I can tell you for a fact that students don't need smartphones in order to unproductively entertain themselves in a robotics lab. - remulasce [more]
Unread 11-02-2014, 22:44
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Re: Is a solenoid required?
Originally Posted by tStano View Post
I see no reason why it would be illegal.
But why not just create a rigid mount; isn't that essentially what you're doing?
I'm sure you've thought this through though, and you know whats going on and have a good reason.
I think you give me too much credit. It was an idea that was bounced around15 minutes before shutting down the build for the day.
Unread 11-02-2014, 22:49
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Yes it is legal. We use it to make an easy shock absorber that is fully adjustable.
You can also put a solenoid to the other side and when equal pressure is applied it allows gravity to move what you are controlling.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
