Is a solenoid required?
Is it legal/ advisable to directly wire a pneumatic cylinder after a regulator so that it is continually supplied with air pressure, without a solenoid? It would be used to apply a constant pressure to something.
Re: Is a solenoid required?
I see no reason why it would be illegal.
But why not just create a rigid mount; isn't that essentially what you're doing? I'm sure you've thought this through though, and you know whats going on and have a good reason. |
It was an idea that was bounced around15 minutes before shutting down the build for the day. |
Yes it is legal. We use it to make an easy shock absorber that is fully adjustable.
You can also put a solenoid to the other side and when equal pressure is applied it allows gravity to move what you are controlling. |
