Re: Solenoid Breakout Always Sending Power
Well it is sending power regardless if the lights are on on the module. We tested it both ways. Yes it is in the 3rd slot.
It shouldn't make a difference for your issue but have you wired the solenoid breakout to 24v and not 12v?
Pictures of your CRIO and PDB would help. |
It is wired to the 24v connector, the same one as the one for the cRIO.
Have you verified that the power input to the Solenoid Breakout is hooked up properly (i.e. not backwards)?
Yes we have checked that. We connected it red-black-red-black in the same place as the cRIO power. And on the other side it follows the positive and negative on the Breakout bumper.
