Go to Post IT ISN'T THE STUDENT'S JOB TO DISCIPLINE OTHER STUDENTS. That's why God invented mentors. Let them do their jobs. - Collin Fultz [more]
Unread 11-02-2014, 21:12
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
Victor 888 PWM Randomly Fail
So last night we were testing our robot and all of our Victor 888's were working and then one by one they died (two of them). They still turn on but keep blinking three times (PWM Error). The two that died were running the two bag motors on our 100:1 Versa-Planetary gearbox. Has anyone had similar issues? This would not be that big of an issue if we were not in the last week of season.
Unread 12-02-2014, 00:13
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Re: Victor 888 PWM Randomly Fail
What have you done to diagnose the issue so far?
Unread 12-02-2014, 00:28
Dr.Gusta's Avatar
Team Role: CAD
We have ruled out a coding error because we used it last night and when the bot was powered on again the next day they did not work after no code changes. We tried switching PWM cables and blowing it out in case some alum dust got on or in it. We have also tried other PWM ports on the sidecar to no avail. That is how we have narrowed it down to the Victor. I don't think something shorted out because if it did the thing would just cease to function. Right?
Unread 12-02-2014, 01:03
Botwoon's Avatar
Not necessarily.
Inspect everything, and don't rule anything out unless it's been checked, double checked, and replaced if possible. Inspect the mechanism that the victors are driving, thoroughly. I'm willing to bet that the fact that the Victors were both involved in the operation of a single mechanism is not a coincidence.
You can replace the Victors to know immediately whether or not they actually failed, but I would personally want to know what is the cause of the issue before I risked losing another pair.
Unread 12-02-2014, 08:48
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Earlier in the build season we had an Andersen Connector with the power cables reversed. That caused us to apply power in reverse to the robot. Our Victor 888's did not fail then, but later started failing just as you describe. We are in the middle of swapping out all 7 of our victors.
Did you have any sort of reverse power to the victors earlier in the build season?
___________________
- Tennyson, Ulysses
Unread 12-02-2014, 10:44
Dr.Gusta's Avatar
Team Role: CAD
I checked our Anderson connector and it is properly labled plus all of the other victors work fine and now we have swapped victors with the drive base ones so we can test the arm and everything seems to be running fine
. Does anyone know where we can buy 2 victors local (Inland Empire) Another team?
Unread 12-02-2014, 11:12
Doc,
Please contact IFI with this issue. They may have some suggestions.
Unread 12-02-2014, 12:34
Dr.Gusta's Avatar
Team Role: CAD
How can I contact IFI I can't find any contact info.
Unread 12-02-2014, 12:35
Aren_Hill's Avatar
Build Nifty Things
http://www.vexrobotics.com/contact
-Aren
A guy who likes robots.
Unread 12-02-2014, 17:31
Dr.Gusta's Avatar
Team Role: CAD
I was able to solve the problem by pushing in the PWM cables in with a bit of force as stated here http://www.chiefdelphi.com/forums/sh...d.php?t=124033
