Go to Post It's often not the code you are focused on that causes problems, but the code you dismiss out of hand as "unrelated". - Mark McLeod [more]
Unread 12-02-2014, 08:41
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Batteries parellel
Originally Posted by Kevin Selavko View Post
Would this allow for hot swapping or would that still be insanely bad?
Possibly, but not recommended. The Schottky diodes allow the power source with the highest voltage to flow current until it's voltage sags below the voltage of the second source. Then they 'share' the current requirements.
Originally Posted by Alan Anderson View Post
What kind of diode would you suggest for this application? Keep in mind that FRC robots use tens of amps on a regular basis, spiking briefly to hundreds of amps. Also consider that a diode's worth of voltage drop is significant.
One of these(Silicon power Schottky diode) might work, although I'd prefer something a little beefier.
Done properly, it's not too dangerous, but done improperly could be catastrophic. That's probably why FIRST doesn't allow it.
___________________
- Tennyson, Ulysses
