Go to Post Congratulations to team 341, your work is nothing short of what I want to do when I grow up. - kjolana1124 [more]
Unread 11-02-2014, 19:05
adanmoran adanmoran is offline
FRC #2809 (Kbotics)
adanmoran is an unknown quantity at this point
Robot communication stops when switching drive direction
We are running a drive train with 2 CIMs and 1 miniCIM per side (6 total). All our talons are calibrated, and the motors drive with no issues in both the forwards and reverse directions.
Our issue is that when we switch directions from forwards to reverse (or vice-versa), the robot communication cuts out entirely. The robot doesn't shut off. We can drive at full speed, stop, then switch and there is also no problem.
Our router is connected to the power distribution board with a 5V transformer.
We've checked the battery, and we don't get any readings below 10V on a full battery.
We've been trying to debug this issue for the past 2 days. The only thing we know for sure is that this problem happens only when motors are driving at 70% of their speed or more. Anything under that and we can switch directions perfectly fine.
Does anyone have some advice? We're kind of stumped.
Unread 11-02-2014, 19:07
Re: Robot communication stops when switching drive direction
The 12V-5V converter is connected to the dedicated 12V supply at the end of the PDB or to one of the terminal pairs on the side?
Unread 11-02-2014, 19:41
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
My guess is that the sudden voltage drop when you switch directions is causing the radio to reset.
Is the radio wired as shown in this diagram?
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 11-02-2014, 19:49
FRC #2809 (Kbotics)
We have it connected to one of the terminal pairs.
Unread 11-02-2014, 19:59
FRC #2809 (Kbotics)
It wasn't set up that way. We're switching it now.
Unread 12-02-2014, 00:00
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Make sure you're wiring to the dedicated 12v port on the end of the PDB (then stepped down to 5v), and not into the 5v port.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 12-02-2014, 09:41
Whatever process your team had in place that resulted in that wiring error may have created other wiring errors, just waiting to cause problems at the worst possible time.
So while you are at it, you might want to consider comparing your entire wiring setup to the wiring instructions provided on the usfirst.org and screenstepslive.com websites.
Unread 12-02-2014, 11:10
Everyone,
This is the first thing for us to check when a team is having this problem. It should be checked during the inspection process but it does sometimes get over looked or more often changed by the team after inspection.
Unread 12-02-2014, 13:33
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Another reason to complete the Inspection Checklist yourself before bagging the robot.
I have 3081's printed in my bag right now.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
