Go to Post "There are two ways to compete in this world, you can drag your competitors down, or you can rise above them. Which is better for the world in the long run?" - Karthik [more]
Unread 12-02-2014, 13:20
Re: Pneumatics with diode
You may build a 24 volt power convertor as a Custom Circuit and feed two solenoid modules (or one in addition to the one fed from the PD power supply.) provided all other electrical rules are followed.
The answer to Q237 says otherwise. :-( It refers to R53, which prohibits custom circuits from affecting the power pathways to a bunch of things including solenoid modules.
