Go to Post My favorite question of all time asked by "outsiders": How much does/did that thing cost? How can you put a price on the hard-work and dedication it took to build these machines? - KyleGilbert45 [more]
Unread 12-02-2014, 13:52
M.Kong-Sivert M.Kong-Sivert is offline
AKA: Mackenzie Kong-Sivert
FRC #2375 (Dragon Robotics)
M.Kong-Sivert is an unknown quantity at this point
Stopping an Axis-Controlled Motor
Our robot has an arm that is supposed to pick up the ball and is controlled by a gearbox, which is connected to a CIM and a Mini-CIM. We used to have it programmed so that the arm was controlled by buttons (one to make it go up and one to go down), but we decided to change it by controlling it with one of the axes instead. This gave us more control, and, overall, we prefer it. However, we designed the arm so that it could stop halfway up to catch the ball, and now we can't stop the arm in the middle anymore. Is there a way for us to program it so that it can stop in the middle? Thank you.
Unread 12-02-2014, 13:57
Re: Stopping an Axis-Controlled Motor
Letting go of the joystick doesn't stop it?
You can add dual controls if the buttons worked better for the middle position, so that the buttons override the joystick.
Unread 14-02-2014, 09:11
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Going along what Mark said, you could try wiring a button in-between the axis and the MotorSet block. When the button is pushed (true), the MotorSet block would recieve the joystick value but otherwise (false) it is set to zero.
If the joystick isn't setting the motor back to zero like it's supposed to, this would guarantee a total stop because of the button override.
Is that the problem you're having?
Per Audacia Ad Astra
