Go to Post The FIRST community will always step up in times of need. - nikeairmancurry [more]
Unread 12-02-2014, 11:36
samn122 samn122 is offline
FRC #0334
samn122 has a spectacular aura aboutsamn122 has a spectacular aura about
Legal to use solenoid breakout as a source of power?
My team wants to power the Allen-Bradley PHOTOSWITCH 42EF-D1MNAK-A2 through the solenoid breakout since it is capable of outputting 24 volts. I can't find any rules or restrictions in the manual on this issue. Does anyone know if it's legal?
Unread 12-02-2014, 11:43
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Legal to use solenoid breakout as a source of power?
R51 along with table 4-4 control what can be connected to the solenoid breakout board. R69 controls the total load for the solenoid breakout. The definition of custom circuit seems to cover photo switches. If the photo switch is a custom circuit & the total load on the solenoid breakout is under R69 the answer would be yes. Otherwise no.
Unread 12-02-2014, 11:53
Originally Posted by FrankJ View Post
R51 along with table 4-4 control what can be connected to the solenoid breakout board. Unless the photo switch falls under a custom circuit definition, I think the answer would be no.
Fortunately, sensors such as photo switches do fall in the category of custom circuits. The only thing you might need to watch out for is the maximum current that can be supplied by the Solenoid Breakout.
Unread 12-02-2014, 13:31
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
I'm curious why you want to run them at 24v. We run them off of the PDB at 12v without issue.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 12-02-2014, 13:39
Those sensors are rated down to 11v, so they perform more consistently while on a regulated power source.
Really lower than than in actual usage, but they can stop functioning at the lowest voltage dips we can see when driving a lot of motors at stall on robot.
They start functioning again when the voltage later rises, so if they aren't actively being used during a pushing contest, then the drivers may never notice.
Unread 12-02-2014, 13:53
See the bottom of Page 2 of this document for an explanation.
Unread 13-02-2014, 14:18
AKA: Steve Peterson
Thanks!
We had some issues last year with the line detectors that could be explained by this.
S
Unread 13-02-2014, 14:28
If the solenoid module is wired to the PD +24 volt power supply, that is maintained down to a battery terminal voltage of about 4.5 volts. I think that is a good choice for a sensor that requires constant power supply.
