Go to Post Antimatter.. It will help us in the never ending quest to build the bot under the weight limit. - Elgin Clock [more]
Unread 12-02-2014, 14:27
Vkamra20 Vkamra20 is offline
FRC #5094
Vkamra20 is an unknown quantity at this point
Unidentifiable Problem
Hey Everyone
Our Robot is having a serious problem, everything on Drivers Station is green but the robot is not moving. Sometimes when we enable "Autonomous" the wheels start to moves. I feel it might have something to do with the Crio, because when we Re-image it works and then stops working. Any advice or solutions would help
Thanks
Unread 12-02-2014, 14:29
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Unidentifiable Problem
What are the lights on your motor controllers doing when you are telling the robot to move?
Unread 12-02-2014, 14:35
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
This is NOT my area of expertise at all, but if you could post your code or at least post what language you're writing your code in so you have the greatest chance of someone helping you out.
The more information the better.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
FRC #5094
The lights are blinking orange
Unread 12-02-2014, 14:37
FirstUpdatesNow.com
Blinking orange means you're speed controllers are not getting a PWM signal. Check your connections between the Speed Controller and the Digital Sidecar and the connections between the Digital Sidecar and the Crio
@jmontois340
Team 3015
FRC #5094
We're programming in Netbeans with Java, and we're currently using a basic arcade drive program.
Unread 12-02-2014, 14:38
FRC #5094
But when we enable autonomous the wheels are moving
Unread 12-02-2014, 14:39
FirstUpdatesNow.com
When you enable Autonomous I can assume at that point the orange lights on your speed controller are no longer blinking?
@jmontois340
Team 3015
Unread 12-02-2014, 14:40
FRC #5094
Yes
Unread 12-02-2014, 14:42
FirstUpdatesNow.com
Seems to me that something in your drive code isn't working quite right. I'm sure others will have ideas as well, posting some of your code might help.
Sorry I couldn't be of more assistance.
@jmontois340
Team 3015
Unread 12-02-2014, 14:49
FRC #5094
Thanks any way
Unread 12-02-2014, 14:57
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
Check to make sure your joysticks are recognized by the driver station and in the USB 1 position.
FRC 1732 (Hilltoppers): Mentor
FRC 2338 (Gear It Forward): Mentor/Alumnus
FRC 4096 (CTRL-Z): Mentor
Unread 12-02-2014, 14:59
Flywheel Police
Could you post your teleop code for us?
Unread 12-02-2014, 16:04
FRC #5094
Ill post an image
Unread 12-02-2014, 16:09
FRC #5094
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.RobotDrive;
public class RobotTemplate extends SimpleRobot {
RobotDrive myDrive=new RobotDrive(1,2);
Joystick driveStick=new Joystick(1);
public void autonomous() {
public void operatorControl() {
while(isAutonomous()&& isEnabled()){
myDrive.arcadeDrive(driveStick);
public void test() {
