How to profile?
Are there best practices around profiling java code on the cRIO?
In the past when programming in LabVIEW we took advantage of the built-in profiler to analyze the performance of our code. Is there something similar that can be done with Java/NetBeans? |
Re: How to profile?
You can see the cpu usage on the driver station while running, other than that I don't know of anything.
Re: How to profile?
You can instrument the code and write the results in a large RAM array.
Then examine the array offline. |
