Go to Post there is no mechanics Barbie. - Iain McLeod [more]
Unread 12-02-2014, 18:38
EliStevens12 EliStevens12 is offline
FRC #4925
EliStevens12 has a spectacular aura aboutEliStevens12 has a spectacular aura about
Wires hanging out
My FRC team was wondering if they could hang wires of of the chaise. Any help wile be greatly appreciated?
Unread 12-02-2014, 18:41
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Wires hanging out
It really depends on what you mean, are you extending outside of the frame perimeter? Regardless, I wouldn't do it as it will almost certainly end up in damaged components.
Unread 12-02-2014, 18:44
FRC #4925
Thanks for the help.
Unread 12-02-2014, 18:46
Nate Laverdure's Avatar
FRC #2363
As opposed to wires hanging out on a chaise?
Unread 12-02-2014, 22:33
Qcom's Avatar
Qcom Qcom is offline
Gearhead
AKA: Quentin
FRC #2996 (Cougars Gone Wired)
Qcom is on a distinguished road
My FRC team was wondering if they could hang wires of of the chassis. Any help wile be greatly appreciated?
You would be risking Disqualification under a multitude of general saftey and electronics rules, but I'd be most worried about the following:
R9
Protrusions from the ROBOT and exposed surfaces on the ROBOT shall not pose hazards to the ARENA elements (including the BALLS) or people.
R37
All wiring and electrical devices, including all Control System COMPONENTS, shall be electrically isolated from the ROBOT frame. The ROBOT frame must not be used to carry electrical current.
Wires could be viewed as hazardous if hanging out of the chassis. If you have wires leading to a manipulator, secure them with zip-ties!
"The systems... They DON'T INTEGRATE!"
Unread 12-02-2014, 23:48
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
You will not be allowed to start the match if the wires are outside of the frame perimeter. If you can't fix it quickly your robot will be disabled. If they come out of the frame perimeter after the match starts and they extend less than 20" then you will not get a penalty however you run a serious risk of them getting ripped out or damaged. So keep them secured inside the frame perimeter and even if they are inside the perimeter keep them in a protected place as well as you can.
Unread 13-02-2014, 08:32
Eli,
The operative word here is "entanglement". Inspectors look for wiring that could be entangled in other robots or in the field elements. While these might be a safety issue, we want to insure you and all other teams can play a full match. If your robot should become entangled with another robot, neither of you will have a good time. If it is necessary for you to have a long umbilical of electrical wiring and pneumatic tubing, you may use small surgical tubing to hold it in place when your mechanism is in the retracted position. Your inspector may help you if your are still struggling with the implementation.
