Go to Post I am sad that the Patriots lost, and I am happy for both teams that won...but I am even more thrilled that for the next two weeks robot building in the midwest comes to a standstill. ;) - Jessica Boucher [more]
Unread 12-02-2014, 17:36
EliStevens12 EliStevens12 is offline
FRC #4925
EliStevens12 has a spectacular aura aboutEliStevens12 has a spectacular aura about
Battery Question
My FRC team looked at the battery holding rule where, if the robot is turned upside down and the battery falls out it is declared ineligible. However we are wondering if it has to be strapped on. We have a piece of sheet metal that is above the robot and we want to know whether or not if the battery can fall on to the sheet metal if the robot is turned upside down. Any information will be a great help thank you.
Unread 12-02-2014, 17:38
AdamHeard's Avatar
Lead Mentor
Re: Battery Question
It's in your best interest to securely attach your battery.
Unread 12-02-2014, 17:55
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
The battery needs to 'stay put' in its position relative to the frame of the robot. In other words, make it so it can't move in any of X,Y and Z dimensions.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 12-02-2014, 18:02
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
You could hold the battery down with chewing gum, but you might have an issue when the battery falls out of your robot after a big hit with a movable or immovable object.
Unread 12-02-2014, 18:22
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Strap the battery down.
The battery is capable of emitting welding levels of current if you short it. Having your safety plan for the battery if the robot is tipped involve dropping the battery onto sheet metal, possibly posts first, is a remarkably bad idea.
Please be safe.
Unread 12-02-2014, 18:45
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
I've seen Ratchet straps and similar industrial straps sometimes not be enough to hold the battery in place. Don't be afraid to take the robot to the crash test track to make sure your battery mount and method of securing it are up to the task.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 12-02-2014, 19:49
DonRotolo's Avatar
Back to humble
FRC #0832
OK Eli, I think you have your answer: That metal is a liability if the battery shorts against it (Bang! Flash! Send For Help! Get it?). A strap is a great idea. (We use a heavy velcro strap. Some teams use heavy Zip ties.)
