Go to Post Rain? Prepare for Armageddon to strike when you go to St. Louis. Two years in St. Louis. Two years of Tornado scares. Tis the season. - Koko Ed [more]
Unread 12-02-2014, 19:00
Andrew Merwin Andrew Merwin is offline
FRC #5464 (Blue Jacket Robotics)
Andrew Merwin is an unknown quantity at this point
Motors run one way but not the other
While testing the robot we realized that all of our non-drive train motors can run in one direction but not the other. When run in the wrong direction the get a low power signal and then spike and then die back down. The direction that works can be reversed in programming, but I need them to spin both ways. We have gone over the programming and the wiring.
Unread 12-02-2014, 19:09
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
Re: Motors run one way but not the other
I'm no programmer but I believe instead of reversing the direction in the code, you just have one button set to go one direction and another set to go in the opposite direction.
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
Unread 12-02-2014, 19:17
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
if you could either post code or describe how your running the motors exactly, that would be very helpful. On your non-drive train, how are you trying to run the motors? off a battery, or with a button? I'm a bit confused as to the error here, sorry.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 12-02-2014, 20:35
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
If you can change it in code, then it is a programming issue.
Unread 12-02-2014, 21:40
Peregrinus Peregrinus is offline
FRC #4800 (Rage Against The Machines)
Team Role: Electrical
Peregrinus is a jewel in the roughPeregrinus is a jewel in the roughPeregrinus is a jewel in the rough
I agree, I'm fairly positive it's a programming issue. You should post your code.
Unread 13-02-2014, 00:11
The cause might be as simple as an incorrectly powered Digital Sidecar. Are all three of its power LEDs lit?
What does the orange Robot Signal Light do when the motors are failing to run?
Unread 13-02-2014, 00:23
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Wee had a similar issue earlier this week. We use a Global variable in Periodic tacks to control two motors. We then right to that variable in Auton or Tele.
What we found that regardless of the value sent to the variable, it always read back positive.
It turns out the data type for the Global was a U32. Unsigned variables can't be negative. So we changed the data type to I32 and everything started working normally.
