Go to Post Remember, just because you saw it on ChiefDelphi, doesn't make it true. - Karthik [more]
Unread 13-02-2014, 09:07
18mfogwell's Avatar
18mfogwell 18mfogwell is offline
AKA: Michelle Fogwell
FRC #4460 (Green MASHine)
18mfogwell is an unknown quantity at this point
Programming Victors in Java
The window motor on our robot is not working. Is the problem in our program??
if(operator.getRawButton(6))
Pulley.set(-1.0);
else if(operator.getRawButton(3))
Pulley.set(1.0);
else
Pulley.set(0);
if(operator.getRawButton(4))
Scoop.set(-1.0);
else if(operator.getRawButton(5))
Scoop.set(1.0);
else
Scoop.set(0);
if(operator.getRawButton(1))
Window.set(-1.0);
else if(operator.getRawButton(2))
Window.set(1.0);
else
Window.set(0);
Any help would be greatly appreciated!
Thanks!!
Unread 13-02-2014, 09:11
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Programming Victors in Java
Can you also post the declaration and initialization of the Victor object?
The things that you have posted seem to be alright, do the other motors work correctly?
Unread 13-02-2014, 09:13
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
if(operator.getRawButton(6)) {
     Pulley.set(-1.0);
} else if(operator.getRawButton(3)) {
     Pulley.set(1.0);
} else  {
     Pulley.set(0);
if(operator.getRawButton(4)) {
     Scoop.set(-1.0);
} else if(operator.getRawButton(5)) {
     Scoop.set(1.0);
} else {
     Scoop.set(0);
if(operator.getRawButton(1)) {
     Window.set(-1.0);
} else if(operator.getRawButton(2)) {
     Window.set(1.0);
} else  {
     Window.set(0);
One thing just for future reference. Convention when writing java is to name your variables with a lowercase letter for the first letter. Also, can I see the code you used to set up the motors? What is the light doing on the motor controller when you try to run it?
P.S. I didn't change anything in the code, just reorganized it a bit.
Unread 13-02-2014, 09:16
18mfogwell's Avatar
Yes, drive motors work (they are not listed in the program above) but none of the motors on victors work which are the ones in the program above.
What is the declaration and initialization of the Victor?
Unread 13-02-2014, 09:17
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
The part where you say Victor Window = new Victor(port);
Unread 13-02-2014, 09:18
Flywheel Police
It's the part where you did this:
Victor Window = new Victor(1);
Are the lights on the victors indicating the motors should be moving, are they blinking orange, or are they staying solid orange?
18mfogwell's Avatar
Here is our whole code.
Unread 13-02-2014, 09:19
18mfogwell's Avatar
The victors blink orange.
Unread 13-02-2014, 09:20
Flywheel Police
That means that they are never getting communication with the cRIO, are you sure that the PWM's are plugged into the correct channels on the digital sidecar?
Unread 13-02-2014, 09:33
18mfogwell's Avatar
Yes. We double checked that they were plugged in correctly, and we put on a brand new Digital Sidecar so no ports should be broken.
Any other ideas?
Unread 13-02-2014, 09:34
Flywheel Police
Any other ideas?
It's not a code issue that I can see. What motor controllers are you using for your drivetrain?
Unread 13-02-2014, 09:35
18mfogwell's Avatar
Jaguars for the driving.
Unread 13-02-2014, 09:36
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
Any other ideas?
Can you take the PWM cable out of the Window motor Victor and verify that all of the pins are 100% straight? Plugging the PWM cable in correctly can sometimes take a few tries and if the pins are even a little bent they may not have been making good contact.
Based on the Victor datasheet, the problem that you are describing is an improperly wired PWM cable or no PWM cable at all.
Indication
: Flashing ORANGE indicator on power up.
Problem
: No PWM signal.
Possible Solutions
1.
Ensure the transmitter and receiver are powered ON.
2.
The PWM cable may be improperly connected.
Check wire color-coding at each end. Check that
the connector is not off a
pin at the receiver end.
3.
Check for a good PWM signal by connecting a
known good servo to the PWM extension cable. If
the servo does not move, this can indicate either:
a) a faulty receiver
b) an improperly connected cable
c) a bad PWM extension cable
Unread 13-02-2014, 09:37
Any other ideas?
Determine if you are actually getting a PWM signal in your PWM cable.
You can use an oscilloscope, or a simple digital voltmeter*, or you can plug the cable into a known-good Jaguar or Talon to test it.
* ask if you want more detail how to do this
Unread 13-02-2014, 10:30
18mfogwell's Avatar
We think that we have verified the problem is in the code. Can somebody look at the code again and double check for errors?
Thanks!
