Go to Post Come on guys....what else could we expect.....its Wildstang!!! - Kyle Love [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 16-02-2003, 10:41
SiliconKnight's Avatar
SiliconKnight SiliconKnight is offline
#0824 (SWAT Robotics)
SiliconKnight is an unknown quantity at this point
Send a message via ICQ to SiliconKnight Send a message via AIM to SiliconKnight Send a message via Yahoo to SiliconKnight
Re: Who has used pneumatic wheels?
We used them last year. They are pretty grippy, and the biggest advantage is because the wheels deform to take the weight, it is a bit more forgiving if you aren't lined up perfectly in the vertical direction, all the wheels will still contact, and you'll get a decent contact patch.
If you are using the sprocket driven hubs, I'd recommend that you put about 2-4 oz of slime (tm) into the inner tube before you inflate them. I've been using slime in my mountain bike(s) for the past 10 years, and can count on 1 hand the amount of times I've had a flat tyre. Once the hubs go on it's dang near impossible to pump the tubes back up, so tire sealant in the tubes to guard against slow leaks (which *will* happen) is a worthy investment. Go to your friendly local bike store for slime, it's a green goop that they sell in a tall plastic bottle.
Happy chips,
-=- Terence
Terence Tak-Shing Tam <ttstam@u.washington.edu>
Engineering Team Captain, SWAT Robotics
http://www.swatrobotics.org
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
Skyway wheels w/o bearings ahecht Technical Discussion 4 22-01-2002 01:25
