Go to Post Inspiration is a two-way street. - Taylor [more]
Unread 13-02-2014, 09:55
TechWarlock TechWarlock is offline
Programming Dude
AKA: Jacob
FRC #1396 (Pyrobots)
TechWarlock is an unknown quantity at this point
Compressor Programming Help
i have code that starts and stops the compressor but it doesnt seem to work. Can anyone see whats wrong with the code
#include "WPIlib.h"
#include "compressor.h"
class RobotDemo : public SimpleRobot
		RobotDrive Frankbot; // robot drive system
		Joystick leftjoy;
		Joystick rightjoy;
		Joystick joystick3;
		Relay Comp;
		Jaguar Winch;
		Jaguar Claw;
		Jaguar Granata;
		Solenoid Sol1;
		Solenoid Sol2;
		Solenoid Sol3;
		Solenoid Sol4;
public:
	RobotDemo(void):
		Frankbot(1, 2), //these are the PWM ports
		leftjoy(1),
		rightjoy(2),
		joystick3(3),
		Comp(1, 1),
		Winch(7),
		Claw(9),
		Granata(5),
		Sol1(1, 1),
		Sol2(1, 2),
		Sol3(1, 3),
		Sol4(1, 4)
	//	usermessages = DriverStationLCD::GetInstance();
	//	Camera->WriteResolution(AxisCamera::kResolution_160x120);
	//	Camera->WriteCompression(20);
	//	Camera->WriteWhite
    //  Balance(AxisCameraParams::kWhiteBalance_FixedIndoor);
	//	Camera->WriteMaxFPS(30);
	//	Camera = &AxisCamera::GetInstance();
	//	myRobot.SetExpiration(0.1); // test
	void Autonomous(void)
		Compressor *c = new Compressor(1, 1);
			    				c->Start();
void OperatorControl(void)
		int Off = 7;
		int On = 8;
		int ClawTurn = 10;
		int ClawTurn1 = 11;
	    int Claw1 = 4;
		int Claw2 = 5;
		int WinchUp = 4;
		int WinchDown = 5;
		int Solup = 2;
	    int Soldown = 3;
		int Sol2Up = 2;
		int Sol2Down = 3;
	    static float speedModifier = 0.7;
		static float speedModifier2 = -0.8;
		Frankbot.SetSafetyEnabled(true);
			    				c->Start();
		while (IsOperatorControl())
			Frankbot.TankDrive(-leftjoy.GetY() * speedModifier, rightjoy.GetY() * speedModifier2);
			if(joystick3.GetRawButton(On)){
						c->Start();
			else if(joystick3.GetRawButton(Off)) {
						c->Stop();
			else {
				c->Stop();
			if(leftjoy.GetRawButton(WinchUp)) {
			Winch.Set(0.5);
	else if(leftjoy.GetRawButton(WinchDown)) {
			Winch.Set(-0.5);
	else {
			Winch.Set(0.0);
	if(rightjoy.GetRawButton(Claw1)) {
					Claw.Set(0.5);
	else if(rightjoy.GetRawButton(Claw2)) {
					Claw.Set(-0.5);
	else {
					Claw.Set(0.0);
	if(rightjoy.GetRawButton(ClawTurn)) {
						Granata.Set(0.2);
	else if(rightjoy.GetRawButton(ClawTurn1)) {
						Granata.Set(-0.2);
	else {
						Granata.Set(0.0);
	if(leftjoy.GetRawButton(Solup)){
			Sol1.Set(true);
			Sol2.Set(false);
		else if(leftjoy.GetRawButton(Soldown)){
			Sol1.Set(false);
			Sol2.Set(true);
		else {
			Sol1.Set(false);
			Sol2.Set(false);
		if(rightjoy.GetRawButton(Sol2Up)){
					Sol3.Set(true);
					Sol4.Set(false);
		else if(rightjoy.GetRawButton(Sol2Down)){
					Sol3.Set(false);
					Sol4.Set(true);
		else {
					Sol3.Set(false);
					Sol4.Set(false);
START_ROBOT_CLASS(RobotDemo);
Any and all help is appreciated, thank you
Unread 13-02-2014, 10:01
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Compressor Programming Help
						c->Start();
						c->Stop();
			else {
				c->Stop();
This says that if you're holding button 8 on the joystick the compressor will run. Keep in mind that the only time that the compressor will run is when that button is held. Is that the intended behavior?
Unread 13-02-2014, 10:04
Programming Dude
AKA: Jacob
that was intended, but is there anyway to do it so that when the button is pressed it turns on and then turns off according to the pressure switch, besides that is anything else wrong with the compressor code because it doesn't run at all.
Unread 13-02-2014, 10:07
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
The call to C->Start() will start the thread that automatically checks the Pressure Switch and shuts off the compressor as needed. Is there a properly connected pressure switched plugged into DIO 1? Also, have you tried using a Relay object and manually starting the compressor? If so, does it function?
Unread 13-02-2014, 10:10
Programming Dude
AKA: Jacob
yeah i used a relay object and it worked the compressor turned on, but it doesnt work with the code currently on it
Unread 13-02-2014, 10:14
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
Can you use a multimeter on your pressure switch to determine whether or not there is an output voltage?
Unread 13-02-2014, 11:11
Programming Dude
AKA: Jacob
thank you for everything, we figured it out, it was our electronics, the pressure switch was wired wrong
Unread 18-02-2014, 12:10
wadehas wadehas is offline
FRC #1258
wadehas is an unknown quantity at this point
Why don't you initialize and start the compressor in the constructor for the Robot?
That is what we we do, and never have to deal with anywhere else.
