Go to Post The best defense is a good offense, never back down - Nawaid Ladak [more]
Unread 10-02-2014, 23:01
stufflikethat stufflikethat is offline
stufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of lightstufflikethat is a glorious beacon of light
Inspectors please help! Protrusion from frame perimeter.
I am working with a team that has bearings holding the the wheel shafts in the robot. The bearings are currently sticking out about an 1/8th of an inch past the frame perimeter. I don't believe this is a problem and should be legal due to 1/4 protrusions being "ignored" also our frame is a bit under 112.
The real questions lies in the bumpers. To make our bumpers work well we were planning on cutting 3/16ths deep slots about 1.5 inches up from the bottom of the bumpers so the bumpers hug the bearings. This will also allow the bumper to be right up against the frame instead of the 1/8th inch. Will the slots be a problem or are they legal?
Please correct me if I said anything that is wrong and will prevent passing inspection.
Unread 10-02-2014, 23:26
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: Inspectors please help! Protrusion from frame perimeter.
The first part of R21 reads:
BUMPERS must be constructed as follows (see Figure 4-8):
A. be backed by ¾ in. (nominal) thick by 5 in. (± ½ in) tall plywood or solid, robust wood. Small clearance pockets and/or access holes in the plywood backing are permitted, as long as they do not significantly affect the structural integrity of the BUMPER.
Emphasis mine. You should be good to go, as long as they're small pockets and don't comprise a large portion of the bumper backing.
Unread 11-02-2014, 07:38
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
You should review the Q&A answers to questions Q231 and Q240. Q231 considers the method of determining the frame perimeter. It rules against a wheel being .08" outside the frame perimeter. The inspectors may not consider a bearing as allowed as a protrusinon. Q240 did not consider a slot as a small clearance. Granted the question asked about a 1-1/2"x 1/2" slot.
You should ask in Q&A for an official ruling.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 11-02-2014, 07:58
Stuff,
The protrusions language is meant to allow for bolt heads, welds, rivets, etc. Bearings are pushing that definition. However, the FRAME PERIMETER as determined by the string method may include the bearings and still be under 112", your OK. I would be more inclined to pass your bumper design if if had shallow holes where the bearings are located rather than one long slot. From your description, it sounds like one or two of the plys in a plywood backing would be compromised. That is pretty significant.
Unread 11-02-2014, 08:16
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Al, am I missing something here? 1/8" protrusion of bearings through the AM14U chassis outer plates will be a common feature of many robots this year, because that is the way the kit chassis was designed.
Do you really think a bumper will be stronger if it is located on the bearing protrusion without a pocket? It seems to me that a clearance pocket, or slot, actually makes the system stronger by enabling more surface contact with the chassis sheet metal.
Richard Wallace
since 2003
Unread 11-02-2014, 08:35
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
I completely agree about the kit chassis design. We are not using it, but we had some of the new kids put together, wire up and program the kit chassis as a learning (for the new kids) and teaching (for the experienced kids) exercise.
I will let Al answer as to his intent, but I tend to agree with what he said that shallow holes are much better than a slot for preserving bumper integrity. Cutting out a slot will greatly increase the chance of a fracture of the bumper at that point compared to a shallow hole.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 11-02-2014, 10:03
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
The protrusion of the bearings on the kit frame would require a slot of slightly less than 1 ply on standard 3/4" plywood. If that puts the bumpers tight against the frame it would be stronger than leaving an unsupported 1/8 gap for the remainder of the frame. Do you want the bumpers to be supported by the frame, or by 12 bolt heads and a bearing? Leaving the bumpers supported by such a small surface area will place all of the force onto your mounts and is more likely to compromise a less than "robust" attachment design. In my mind this presents a safety hazard. To me, Slots are the way to go, but FIRST and FRC inspectors have some rules that only make sense in FRC, not necessarily the real world. Even then some of them don't make sense in FRC...
In short, keep slots shallow and blind and make sure your mounting points take all of the forces straight to the frame.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 11-02-2014, 11:22
The OP stated a slot 3/16" deep, giving my worst case 1/4" with inaccurate routing. I do like tight bumpers but I do not want teams to try and satisfy an inspector and then bind bumper against bearings. Holes just seemed like a better solution. I hate the smell of burning wood in the morning.
Unread 11-02-2014, 11:36
mott's Avatar
mott mott is offline
AKA: Mike Ott
FRC #1619 (Up-A-Creek Robotics)
mott is on a distinguished road
Ditto here...
We initially considered altering our design to avoid the bearing protrusions but once we realized our properly assembled kit chassis was built that way, we elected to leave our custom chassis that way as well.
I'd suspect quite a debate from a large number of teams if inspectors rule this "illegal".
Unread 11-02-2014, 11:39
Oblarg Oblarg is offline
AKA: Eli Barnett
Originally Posted by mott View Post
Ditto here...
We're using the KOP chassis, and while I'm reasonably comfortable we have enough wiggle room to pass the frame perimeter test even if they count the bearings, I'd be rather surprised/frustrated/angered if this were counted as part of the frame perimeter, given the design of the kitbot and the wording of the rules (bearings certainly seem "minor" to me).
What would the point of ruling this illegal actually be, other than possibly disenfranchising a lot of teams for absolutely no reason?
"The breakfast of champions!"
Unread 12-02-2014, 20:29
DonRotolo's Avatar
Back to humble
FRC #0832
One could also state that the bearings define the frame perimeter in that area and manage that issue. Sure, it is not a fastener. Nobody says the Frame Perimeter must be straight. Bumpy is OK (within reason)
Unread 12-02-2014, 23:33
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
With 4" wheels, the bumper zone starts at the centerline of those bearings. That means that a slot in the backing to straddle the bump doesn't seem to be a significant alteration of its strength. It seems pretty radical to consider the bearing protrusion to be part of the perimeter. With a cutout, there would be a lot of backing board inside the perimeter. How much of the backing board is allowed to be inside the frame perimeter?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 13-02-2014, 07:39
Bill et al,
The bump of a flush mounted bearing is not at issue and should be viewed in terms of the "minor protrusion no greater than 1/4"" that a bolt head or weld produces. I do not want teams to think that pillow blocks or other mounted bearings mounted on the outside of the frame will be looked at in the same light. "Minor" is the operative word here.
These are a sampling of what I am thinking might need to be included in the Frame Perimeter determination, depending on use and orientation.
http://www.mcmaster.com/#standard-mo...arings/=qob3vi
http://www.mcmaster.com/#standard-mo...arings/=qob4nq
http://www.mcmaster.com/#standard-mo...arings/=qob4x1
Unread 13-02-2014, 09:55
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The pillow block / mounted bearing would protrude way past a 1/4 inch clearly ceasing to be minor even in the most liberal reading of the rule? You then run into issues with 1/2" support on either side of the vertex as well.
In the past (Just for you Al ) In this case the rule wording is similar though. We drilled thru holes in the bumpers to give clearance for axle bolt heads. 1 inchish Dia to allow for sloppy location. The little decrease in plywood strength was more than made up by solid contact with the frame.
Does gussets fall in the minor protrusion category assuming the gusset + rivet is less than 1/4 inch?
Unread 13-02-2014, 10:08
Frank,
Gusset on the frame or on the bumper? We will see both.
