Go to Post In other words, don't count your chickens before they hatch, even if the shell seems broken. - Lil' Lavery [more]
Unread 13-02-2014, 13:29
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Nothing works on the robot :/
Originally Posted by matthewdenny View Post
The input side of the Talon is 12.8, the output side is 0. When the robot starts up, the talons are all blinking at ~1 Hz, orange. After code is deployed, 3 of the talons switch to being the red/orange fast flashing/solid the input side side of the talons remains at 12.x volts, the 3 talons that change to red/orange go to .2v on the output, and the one that blinks at 1Hz is 0V at output.
The Crio has the power light lit. I think the radio is working because we can get the video stream from the camera.
Have you tried calibrating the Talons?
Press the Calibrate button on them and hold it, send them -1.0; 1.0; and then 0.0 and then release the Calibrate button.
