Go to Post We might just dip the entire bot in a Locktite bath before bagging. - Kevin Ray [more]
Unread 13-02-2014, 09:35
Al's Annual Inspection Thread
OK,
Another year and another list. As we wind down to stop build in a few days, teams should be thinking about inspections coming up and should be performing a pre-bag inspection of their own.
1. The inspection checklist and the BOM template are both located here...
http://frc-manual.usfirst.org/
2. As Q&A or Team Updates modify robot rules, the Checklist may also change to reflect the rules change.
3. Stored Energy. Just about every robot will have some form of stored energy this year. To keep safety in mind at all times, springs will get an extra look by your inspectors. You may be asked to "dry fire" a shooting mechanism to check for the possibility of "destructive disassembly". If you are using COTS springs, please think about adding some type of cable (aircraft cable preferred) to keep the parts together should the spring crack or fracture. If you are using surgical tubing or some other form of latex or rubber, please be sure to have the ends secure. Inspectors may ask Safety Advisers for assistance in determining the safety of these mechanisms.
4. Bumpers. These are an issue every year and I am only mentioning them here so you can think about them. Bumpers do not need to be included in your bag with the robot. You do need them at competition and they will be required for practice rounds on the field. There has been a recent Team Update that allows you to use tape or other fasteners to affix the pool noodles to the "robust wood" to aid you in making pretty bumpers while you secure the fabric covering. Whatever method you choose, the intent is not to change the overall cross section of the pool noodle or compress it nor to add hard parts beyond the 1" dimension from the frame. Please refer to Fig. 4-8 for guidance.
5. Pneumatics. As last year, you are allowed to use any 12 volt DC compressor that does not exceed 1.05 cfm. If your compressor is not a common type, please be ready to provide documentation to show it meets spec. A new compressor that has become available requires a stainless steel, woven hose ( provided and as stated in the manufacturer's spec sheet) for operation. That has been ruled by the Q&A as part of the compressor and must be included. Reminder that pneumatics parts must be unmodified COTS devices rated for 125 psi working pressure.
More to follow, good luck everyone.
Unread 13-02-2014, 09:42
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Al's Annual Inspection Thread
3. -snip- You may be asked to "dry fire" a shooting mechanism to check for the possibility of "destructive disassembly". If you are using COTS springs, please think about adding some type of cable (aircraft cable preferred) to keep the parts together should the spring crack or fracture. If you are using surgical tubing or some other form of latex or rubber, please be sure to have the ends secure. Inspectors may ask Safety Advisers for assistance in determining the safety of these mechanisms.
Does this affect pneumatic-based catapults? If so, will we be required to run it through the Driver Station/program or would the manual overrides provided on the Solenoids be acceptable for showing a test fire?
Unread 13-02-2014, 09:44
Yes and we will ask you to dry fire using an powered and enabled robot in a protected area of the venue or a corner of the practice area if safe for others.
Unread 13-02-2014, 09:54
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
How does that work for all electric shooters? We have several shooter presets and a slow manual mode. Will/ could inspectors ask for us to dry fire all of them? Its powered by 6 cims so dry firing it could cause a problem.
Also if we instal a sensor to prevent dry firing (right now it just takes a button sequence) then will we be asked to bypass that sensor or will that exempt us from that test?
Unread 13-02-2014, 09:56
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I'll chime in here with my biggest concern: R8, specifically the "cause unsafe conditions" part. This year many, many teams will utilize springs or tubing to create a mechanism that can fire with a lot of power. The last thing we want to see is a team picking up their robot and the thing firing without warning, injuring a student when it hits them on top of the head or under the jaw (given the speed and power of these shooters, I wouldn't be surprised if this caused a serious concussion or broke a jaw). Please, Please, Please design in some safety interlocks to make sure this doesn't happen! A locking pin, or a carabiner that can keep the shooter from hitting someone carrying the robot is really all that's needed.
2016: Lake Superior WFFA
Unread 13-02-2014, 10:05
Max,
Should an inspector request a dry fire, it is because the mechanism looks unusual or appears to impart a large energy transfer. We are concerned about that "destructive dis-assembly" mentioned above. Many of our inspectors have seen these types of mechanisms over the years, and our concern is first and foremost the safety of all participants and audience. The last thing we want is a mechanism coming apart and launching it's kicker into the stands and injuring a grandmother or young child. We certainly feel a need to protect the field personnel. You don't want to hurt a ref or judge do you?
Unread 13-02-2014, 11:15
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Spontaneous Deconstruction can plague any type of shooter. Elastic or electric or pneumatic
Unread 13-02-2014, 13:51
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
Originally Posted by Max Boord View Post
... Also if we instal a sensor to prevent dry firing (right now it just takes a button sequence) then will we be asked to bypass that sensor or will that exempt us from that test?
Al:
This is our situation as well. Pneumatic shooter, ball sensing interlock (eg shooter doesn't fire if the ball isn't present.) If we need to disable the interlock, we would rather do this in a way that is consistent with the interlock being as fail-safe as possible.
We'll certainly comply, but the ball (between it's weight, as well as it's air resistance) has a significant impact on the loads and speeds that the shooter sees when fired.
-Karlis
Why does this year's game remind me of Violet in Willie Wonka? Hmmmm?
So true. There are now two clips that I will forever look at differently. (The other is the image of the Poofs singing "Call Me Maybe" to Karthik - always brings a smile whenever I hear that song being played.)
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
Unread 13-02-2014, 14:24
Karlis,
Your RI will figure it out when you are inspected.
Unread 13-02-2014, 14:40
Joining the 900 Meme Team
FRC #0079
Karlis,
I'm sorry, that's unacceptable.
If there is a system in place to prevent dry firing is an inspector asking a team to bypass it a reasonable request? Should we anticipate it? Could you provide guidance under what circumstances this request may be made? (Being more specific than 'at the discretion of your RI' would be greatly appreciated) I am merely trying to understand the circumstances under which an inspector should ask a team to disable a safety mechanism which the team has deemed necessary given the behavior of their system.
I do not recall any such behavior in 2008 when more energy was stored.
Unread 13-02-2014, 14:55
Have you ever seen a fool-proof mechanism or sensor on a FIRST robot? I know I haven't... It would take quite a bit for a team to convince me that whatever system they have in place to prevent a dry fire isn't going to break at some point during the competition and allow the system to dry fire anyways. We've all seen some crazy stuff happen to a robot that no one expected...
Unread 13-02-2014, 15:16
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
If you don't the ability to do stuff manually in your code, then you are setting yourself up for failure. What happens if a sensor goes out during a match....you still want to be able to function without the sensor.
So honestly, just figure it out and stop crying about it...
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 13-02-2014, 15:18
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
So what I think Al and Jon are saying is that you should (and RI's will) assume the worst case that your robot will dry fire at some point unexpectedly regardless of your mechanisms designed to prevent that, because mechanism fail, especially when interactive with other bots.
If it only fires 'safely' with a ball loaded, then that is not good enough, and the robot is considered to be too unsafe for FRC standards, and it probably shouldn't be good enough for your team's standards due to the risk of serious injury.
Make sense?
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 13-02-2014, 15:21
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
That is not always the case. There are many times I'd prefer to not do something if a sensor goes out during a match than have manual control over it. I don't want a motor over driving through a hard stop because an encoder went out and the motor was manually over driven. Better to lose one match than break something on the robot.
Also, no need to be rude about it.
Unread 13-02-2014, 15:22
magnets's Avatar
magnets magnets is offline
I agree, there are no robots out there that are perfect.
You're saying that inspectors need to make sure that when the robot malfunctions, it's safe.
So, let's look at another malfunction. If my robot were to try to fire a ball as the intake was stowed, I'd break my intake. Does the inspector need to watch me break my robot that way too?
However, dry firing my shooter will break it, but pose no safety hazard.
This whole test is a bit stupid. It's kind of like asking teams to drop their robots from the top of the pyramid to make sure that when it falls, it isn't dangerous.
