Go to Post FIRST doesn't just prepare you for engineering, it prepares you for life - sciguy125 [more]
Unread 13-02-2014, 13:36
Vkamra20 Vkamra20 is offline
FRC #5094
Vkamra20 is an unknown quantity at this point
Compressor Problem!
Our compressor's not working but the spike rely is receiving power. Here how our program looks-
package edu.wpi.first.wpilibj.templates;
public class RobotTemplate extends SimpleRobot {
Compressor compressor = new Compressor(2,2);
public void operatorControl() {
// autonomous();
compressor.start();
Any advice will help
Thanks
Unread 13-02-2014, 13:42
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Compressor Problem!
// autonomous();
compressor.start();
Thanks
Have you verified that the spike and the switch are both plugged into the correct spots on the digital sidecar?
Unread 13-02-2014, 13:48
FRC #5094
Yes we have
Unread 13-02-2014, 13:52
Flywheel Police
Yes we have
Have you verified that the switch actually works and is giving the signal you'd expect?
Unread 13-02-2014, 14:00
FRC #5094
We know the switch is getting a signal as well. There is a clicking sound.
Unread 13-02-2014, 14:06
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Make sure your pressure switch is correctly wired and works as expected.
Our biggest problem with getting that exact code to work in past years is that even if the relay is properly set up, a messed up pressure switch will not allow the compressor to start.
If the pressure switch returns a value of false (or true, i dont remember) then the compressor will not start.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Flywheel Police
What is the light on the spike doing?
Unread 13-02-2014, 14:11
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
[my team has had worlds of trouble with the ViAir compressor--so much so that we even mounted that blue-box fan thingy that came with the KOP on the top of it to blow air down on the head constantly and it STILL LOCKED UP.
I'd say if you've tested and proved that you have 12V to the compressor, the only logical thing is the compressor doesn't work.
We have the old Thomas (415?) compressor on our robot now and it's WONDERFUL. if you can lay hands on one and have the weight, that's the ticket.
Bob team 1108.
Unread 13-02-2014, 14:19
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Is the switch wired to the GROUND and SIGNAL on the PWM?
White and Black, Red not used. . .
The sooner we get behind schedule, the more time we have to catch up.
Unread 13-02-2014, 14:29
FRC #5094
The light is orange(not blinking though). The wires on the switch are indeed black and white. Turning on "Tele Op" we hear the click sound. The compressor does work when we manually power it.
Unread 13-02-2014, 14:39
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
For what it's worth, I believe it's a 405ADC.
Our experience has been similar - the Thomas compressor is pretty indestructible. (Though the actual performance, especially at elevated pressure, of the Viair is better.)
-Karlis
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
Unread 13-02-2014, 15:05
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Where is this click coming from? Personally, I've never heard the pressure switch give an audible click...
Take out your multi-meter and measure the resistance of the switch as you pressurize the system - you should see the change when you get to 110-120 PSI. You'll see it change back when it gets down to about 90 PSI. That's how you know the pressure switch is working.
Next, plug it into the DSC, and add a print statement in your code so you can see the value of the switch. Go through the same pressurization routine and make sure the value flips as expected. That's how you know the system is recognizing the pressure switch is being triggered.
Now, take a look at the LED's next to the relays on the DSC - does one of them light up when you expect the compressor to turn on? That's how you know the code is starting the compressor correctly.
Almost there, now take a look at the spike. It should have a solid orange LED when the compressor should be off, but when it should be on (aka when the LED on the DSC turns on), the light should switch to green. That's how you know the relay is doing what its supposed to to.
Finally, does the compressor turn on when the light on the relay turns on? That's how you know you have a complete working system.
Walk through these steps one at a time, from top to bottom. Eventually, you'll find the step where stuff stops working, and you'll be able to isolate your problem and fix it. Until you do that, we can't tell if it's code, a bad wire to the spike, a bad wire to the pressure switch, a bad pressure switch, a bad DSC, or a bad compressor.
2016: Lake Superior WFFA
