Go to Post If you build offensively, keep defense in mind always for defense will always keep you in mind. - Molten [more]
Unread 12-02-2014, 16:31
Ramtech59 Ramtech59 is offline
FRC #0059 (RamTech 59)
Ramtech59 is an unknown quantity at this point
What sensors are used to detect the hot LED lights on the FRC field?
My team and I are trying to use sensors on our robot to help us in autonomous, but we were wondering which sensor could be used to detect the hot LED lights on the field and where we could buy them.
Unread 12-02-2014, 16:40
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
Re: What sensors are used to detect the hot LED lights on the FRC field?
Look in your kit of parts received on kickoff day for the grey section of light reflective tape, hook up the camera properly so you can see the image on your drivers station screen, and attach a light source near the lens of the camera, then aim it directly at the reflective tape (there are different sections of that type of tape on each alliance wall including the hot side flip boxes), look at the image on your screen (the tape will reflect back the light based on the color of the light source you actually aim at it). Then read up on programming a bunch.
Good Luck!
Unread 12-02-2014, 19:52
DonRotolo's Avatar
Back to humble
FRC #0832
We are using the Axis camera to detect the yellow LEDs surrounding the high goal during autonomous.
Unread 13-02-2014, 12:36
thanks for the replies, me and my team appreciate the help given to us.
Unread 13-02-2014, 13:01
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Don,
I was thinking of doing this too, did you buy the lights the field uses, or did you have access to a field that did? Once the bot is in the bag, we are working on hot goal detection, anything you can share?
The sooner we get behind schedule, the more time we have to catch up.
Unread 13-02-2014, 13:56
Lightfoot26's Avatar
Lightfoot26 Lightfoot26 is offline
Just Out For A Rip, Bud...
AKA: Seth Lightfoot
FRC #1625 (Winnovation)
Lightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really nice
We are using a photoelectric IR sensor. We will dead reckon before the match, it acts as a digital input and sends true when it sees the retro reflective tape. False if otherwise, process of elimination... If False then 1 goal is hot, if true, the other is hot. Simple elegant solution... If we don't have to use vision... we find every way not to. although some years we can't get around it... (i.e. 2012).
Winnovation Team 1625 (2010-??)
  • Electrical/Programming Captain (2011-2013)
  • Auxiliary Driver (2012-2013)
  • Team Captain (2013)
  • Alumni (Graduated May 2013)
  • Electrical and Programming Mentor (2014-??)
Unread 13-02-2014, 14:05
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant future
How are you using the photoelectric sensor to detect if the goal is hot or not? Also how can you tell if you are detecting the vertical strip vs the actual hot goal?
Unread 13-02-2014, 14:20
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Yes, remember there is an always "hot" reflective vertical strip adjacent to the variable horizontal one.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 13-02-2014, 14:33
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
I am interested in this as well.
What sensor are you using? The hot goal is determined by a vertical and horizontal rectagle being present.
Based on section 2.2.4 of the game manual "Before the MATCH starts and throughout TELEOP, both dynamic VISION TARGETS are positioned such that the the reflective material faces the FIELD."
So before a match, both left and right sides are "Hot". When Autonomous starts, one side has their horizontal bar rotated away, so that indicates it is notHot, and the other side is.
How can you determine the presents of both horizontal and vertical targets exisit with an IR sensor? I believe the IR sensor will at least always see the Vertical Bar and return true, no?
-Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 13-02-2014, 15:04
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
sensor we are using: human eyeballs...
By using a Kinect on the driver's side during AUTO.
Now the question is, how many posts there will be before someone tells me that this is illegal. My guess: 4
Unread 13-02-2014, 16:52
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Originally Posted by tr6scott View Post
Don,
I'm also quite curious about this. It had crossed my mind, but I didn't get any further than that with the idea.
Are the individual LEDs close enough together and bright enough that they don't simply appear as individual spots of light without making the filtering stage too permissive?
Unread 13-02-2014, 17:17
Controls Engineer
AKA: Kevin
I believe what you are attemping to do IS perfectly legal.
Unread 13-02-2014, 17:22
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
Confirmed in Q&A #55.
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 13-02-2014, 19:30
DonRotolo's Avatar
Back to humble
FRC #0832
No, we got LEDS from SuperBrightLEDs.com, they were a lot less expensive. Also see my PM to you Scott.
They're 2 or 3 inches apart, but the camera sees them as a 'blob' and not pinpoints of yellow. I don't have the details, but they tell me that the filter is relatively permissive because it's not expected to tell us anything more than "Yep the LEDs are on". We're not using the LEDs for aiming or anything like that, just "Is it hot?"
Unread 13-02-2014, 19:34
They should be sure to test with these images: http://firstforge.wpi.edu/sf/go/proj..._vision_images
