Go to Post I've never liked the pressure pads. This just confirms my suspicions: Pressure pads hate robots. It must be some inferiority complex or something. - Andy A. [more]
Unread 13-02-2014, 12:38
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Nothing works on the robot :/
So we have wired the robot and tried to download the code and basically... nothing.
Here's the synopsis:
Electrical:
-4 Cims each is connected to a Talon
-The talons are wired correctly, with M+/M- going to the motors, and V+/V- going to the PD board.
-The PWM cable has the black plugged in to the 'B' side of the Talon, and the "-" side of the Digital side car.
Hardware:
-The DS is plugged into a 30 Amp breaker
-The 3 lights are on the DS
-The ribbon cable is connected to the DIO module on the Crio
-3 of the Talons blink between orange and red very fast, so fast it may actually be solid. The other one just blinks orange ~1hz
Software: About a week ago we ran this setup on the table before attaching it to the Robot. The motors worked at that time.
In an attempt to get it to move this is the code we deployed:
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboar d;
public class RobotTemplate extends IterativeRobot {
Talon Motor1 = new Talon(1); // Motors
Talon Motor2 = new Talon(2);
Talon Motor3 = new Talon(3);
Talon Motor4 = new Talon(4);
public void robotInit() {
public void autonomousPeriodic() {
public void teleopPeriodic() {
Motor1.set(1.0);
Motor2.set(1.0);
Motor3.set(1.0);
Motor4.set(1.0);
public void testPeriodic() {
public void disabledPeriodic(){
} // Closes Robot Template1
Any ideas?
We tried switching out DS, and ribbon cables.
Unread 13-02-2014, 12:42
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Nothing works on the robot :/
Which lights are lit on the DSC?
Unread 13-02-2014, 12:43
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
Does the robot turn on? What lights up and what color is it?
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
Unread 13-02-2014, 12:48
You're supposed to power the Digital Sidecar through a 20 A breaker.
The Talon user manual includes this paragraph:
Talon SR – The Talon SR has an additional LED state that blinks
red/orange when a fault state is detected. A fault can be caused by
one of three things; under voltage (< 3.3V DC), over temperature
(>170 degrees C) or a shorted output transistor. During a fault the
output of the Talon is disabled until the fault condition is no longer
present.
What voltage do you see on the V+/V- pins of the Talon?
What is the battery voltage?
What is the orange Robot Signal Light doing when you try to run the motors?
Unread 13-02-2014, 12:56
FRC #6054 (Dukes)
The robot turns on (it seems) 3 talons are solid orange/red, and the other blinks orange. The RSL blinks, the 3 lights on the DSC are on solid, the 5v,12,and 24v lights on the PD board solid. None of the red lights on the PD are lit.
We did try turning on a solenoid in the code, and the corrosponding light on the Crio relay module turned on and off.
Were there any other lights I overlooked?
Unread 13-02-2014, 12:58
FRC #6054 (Dukes)
The battery voltage is 12.8 The RSL blinks fast until code is deployed, and the slower.
Unread 13-02-2014, 13:11
FRC #6054 (Dukes)
The input side of the Talon is 12.8, the output side is 0. When the robot starts up, the talons are all blinking at ~1 Hz, orange. After code is deployed, 3 of the talons switch to being the red/orange fast flashing/solid the input side side of the talons remains at 12.x volts, the 3 talons that change to red/orange go to .2v on the output, and the one that blinks at 1Hz is 0V at output.
The Crio has the power light lit. I think the radio is working because we can get the video stream from the camera.
Unread 13-02-2014, 13:28
FRC #6054 (Dukes)
When the PWMs are removed the talons return to normal blinking.
Unread 13-02-2014, 13:29
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
Have you tried calibrating the Talons?
Press the Calibrate button on them and hold it, send them -1.0; 1.0; and then 0.0 and then release the Calibrate button.
Unread 13-02-2014, 13:37
FRC #6054 (Dukes)
We haven't done this yet, would uncalibrated talons cause no motion at all?
Unread 13-02-2014, 13:52
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
We had to calibrate our Talons before they worked. As soon as we turned on the robot it would just flash Red. As soon as we Calibrated them, they started working.
Unread 13-02-2014, 13:58
FRC #6054 (Dukes)
We will try this asap and report back.
Unread 13-02-2014, 14:19
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
You may also what to remove the motor leads from the Talons, (with the power off of course) and then do a calibration.
From that point if the error is still there then you may have bad Talons but if the problem is gone then try hooking up the motors one at time and see what happens.
Unread 13-02-2014, 15:53
FRC #6054 (Dukes)
Calibration did the trick! thank you!
Unread 13-02-2014, 20:35
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
Glad to hear that it worked out for you.
