Go to Post As we were lying the robot down to work on it "CAD me like one of your french robots" - 1uan [more]
Unread 13-02-2014, 16:21
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
Re: SmartDashboard causing Watchdog errors
Can you confirm that when your SmartDashboard code is removed that your robot does not have WatchDog problems? Can you confirm that the causation of the problem is based on the presence of SmartDashboard calls?
The reason I ask is because there are many different ways to get that error. Should the problem be related to the SmartDashboard, my guess would be MamaSpoldi's -- that those calls are slowing down the loop too much for the WatchDog's taste.
However, I have not seen that error before with regards to the SmartDashboard. At least, not on Java.
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
