Go to Post the few, the proud, the animators. - BuddyB309 [more]
Unread 13-02-2014, 15:12
TheoBlacksmith's Avatar
TheoBlacksmith TheoBlacksmith is offline
Lead Programmer
FRC #0806 (Brooklyn Blacksmiths)
TheoBlacksmith is on a distinguished road
Programming Ring Light [Java]
Hi, Even though we are not a rookie team, this is the first year we have used a LED ring light. I have a few years experience with Java and though i have put several days into trying to program this light in java, I cannot figure it out. Right now we have 1 LED ring light hooked up to a Spike that is in turn connected to Digital I/O port 2 on the Digital Sidecar. Right now I just want to toggle the light with a trigger on the joystick. This is not the final thing I want though, it's just for testing. Any help will be appreciated.
No matter what, It's always a programming problem
-Everyone Else On The Team
Unread 13-02-2014, 15:30
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: Programming Ring Light [Java]
If you're using a Spike Relay, then the signal cable should be connected to a Relay port on the sidecar, not a DIO port.
In your code, you'll want to use the Relay class. You use the Relay#set() method to control the output of the relay:
// Create the relay
Relay ledRelay = new Relay(RELAY_PORT);
// Control the relay
ledRelay.set(Relay.Value.kOn);
ledRelay.set(Relay.Value.kOff);
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 13-02-2014, 15:37
Lead Programmer
Thanks for that, but that is the first thing that i tried, I moved over to the I/O ports because others seemed to be doing that. Ive been all over the Digital Sidecar.
Unread 13-02-2014, 15:54
When you call the Relay#set() method, the LEDs next to the relay ports on the sidecar change to indicate the state of each relay (red for reverse, green for forwards/on). Did you see these lights change while testing?
Could you post the relevant portions of your code? That will help to track down the problem.
Another option you might have would be to wire your LED light to the solenoid module and use the Solenoid class to control it.
Unread 13-02-2014, 16:06
Lead Programmer
While testing, I see the lights light up on the right relay channels. we also know that the spike and LED are wired up correctly because we placed the PWM for the compressor spike in the LED spike and the LED lit up. The only issue we could be having is a faulty PWM, but we switched it out twice.
Unread 13-02-2014, 16:08
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Perhaps you wired the ring light incorrectly. Try reversing the wires.
Unread 13-02-2014, 17:33
Lead Programmer
Okay, it seems that the PWMs weren't in place properly. The light is toggled now, but i have another issue. when the button is pressed, the light simply flashed and the light on the spike shuts off. This can be repeated by pressing the button again and again, but the light never stays on.
Unread 13-02-2014, 17:46
nyaculak nyaculak is offline
FRC #0053 (Area 53)
nyaculak will become famous soon enough
We will be able to better help you debug your code if you post it here.
On another note...Do you really need to be able to turn the led ring on and off? It would be a lot easier to just connect it to the PDB.
2013 MUC DC 3rd Place, FRC DC Regional, FRC Chesapeake Regional
2012 FRC DC Regional, FRC Chesapeake Regional
ERHS Robotics Club
- FRC Team 53 "Area 53"
www.erhsroboticsclub.org
Unread 13-02-2014, 17:52
Lead Programmer
Here is the Code:
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.Relay;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.SpeedController;
import edu.wpi.first.wpilibj.GenericHID.Hand;
import edu.wpi.first.wpilibj.AnalogPotentiometer;
public class ASimpleJavaBot extends SimpleRobot {
// Constants
private static final Hand LEFTHAND = Hand.kLeft;
private static final Hand RIGHTHAND = Hand.kRight;
Solenoid launcherClosed = new Solenoid(1);
Solenoid launcherOpen = new Solenoid(2);
Solenoid armsClosed = new Solenoid(3);
Solenoid armsOpen = new Solenoid(4);
SpeedController frontRight = new Victor(3);
SpeedController frontLeft = new Victor(2);
SpeedController rearRight = new Victor(1);
SpeedController rearLeft = new Victor(4);
SpeedController rightArmMotor = new Talon(6);
SpeedController leftArmMotor = new Talon(7);
Compressor compressor = new Compressor(1, 1);
Relay Light = new Relay(2);
Joystick joy1 = new Joystick(1);
XboxController cont1 = new XboxController(1);
XboxController cont2 = new XboxController(2);
RobotDrive drive = new RobotDrive(frontLeft, rearLeft, frontRight,
rearRight);
* This function is called once each time the robot enters autonomous mode.
public void autonomous() {
* This function is called once each time the robot enters operator control.
public void operatorControl() {
int count = 0;
compressor.start();
boolean armsDown = false;
boolean ltPressed = false;
drive.setInvertedMotor(RobotDrive.MotorType.kFront Left, false);
drive.setInvertedMotor(RobotDrive.MotorType.kRearL eft, false);
drive.setInvertedMotor(RobotDrive.MotorType.kFront Right, true);
drive.setInvertedMotor(RobotDrive.MotorType.kRearR ight, true);
if (ltPressed == false) {
if (cont2.getTrigger(LEFTHAND) == true) {
if (armsDown == true) {
armsOpen.set(false);
armsClosed.set(true);
armsDown = false;
ltPressed = true;
else {
armsOpen.set(true);
armsClosed.set(false);
ltPressed = true;
armsDown = true;
} else {
if (cont2.getTrigger(LEFTHAND) == false) {
ltPressed = false;
if (cont2.getBumper(LEFTHAND) == true) {
// up
rightArmMotor.set(1);
leftArmMotor.set(-1);
if (cont2.getBumper(RIGHTHAND) == true) {
// down
rightArmMotor.set(-.7);
leftArmMotor.set(.7);
if ((cont2.getBumper(RIGHTHAND) == false)
&& (cont2.getBumper(LEFTHAND) == false)) {
rightArmMotor.set(0);
leftArmMotor.set(0);
if (cont1.getBumper(RIGHTHAND) == true) {
Light.set(Relay.Value.kOn);
if (cont1.getBumper(RIGHTHAND) == false) {
Light.set(Relay.Value.kOff);
private static double RoundToDecimalPlace(double value, int decimalPlaces) {
double exponent = 10 ^ decimalPlaces;
int rounded = (int) (value * exponent);
return (double) rounded / exponent;
Unread 13-02-2014, 17:57
// Create the relay
This will not do what you expect. kOn sets both outputs of the spike to 12v, which will cause a motor or an LED to be off. You should use kForward.
You can use kOn if you set the direction of the relay to Forward only.
Unread 13-02-2014, 18:09
Lead Programmer
Thank you,
The kForward worked for me.
Unread 13-02-2014, 18:54
I guess I was assuming that kOn would be equivalent to kForward by default; thanks for the heads up. So adding a call to Relay#setDirection() would give the desired behavior, right?
// Create the relay
// Specify the direction for the relay
ledRelay.setDirection(Relay.Direction.kForward);
Normally I would just use kForward. The reasoning here was to avoid accidentally setting the relay to kReverse and potentially damaging the LEDs. Granted, it's easy enough to just remember not to use kReverse...
Unread 13-02-2014, 19:02
Yes.
The nice thing about LEDs is they can't be damaged by reverse polarity (unless the thing you're driving has integrated control electronics also, but then you probably wouldn't be driving it from a spike).
Unread 13-02-2014, 21:11
FRC #0053 (Area 53)
The code supplied is not going to work at all. The operatorControl() function is only called once, so it's necessary to surround all of the control logic in a while loop
while(isEnabled() && isOperatorControl()) {
    // code goes here
ERHS Robotics Club
Unread 14-02-2014, 12:22
Lead Programmer
I'm not sure what you are talking about Nyaculak. The code here works just fine for me.
