Go to Post However, in the end, the renderer is only as good as the artist. - MiNT [more]
Unread 13-02-2014, 18:29
TechWarlock TechWarlock is offline
Programming Dude
AKA: Jacob
FRC #1396 (Pyrobots)
TechWarlock is an unknown quantity at this point
Break/Coast feature
Does anyone know how to program the jaguars to break using windriver I've searched up anything I could find about the break/Coast feature but I can't find out how to program it anywhere
Any help is appreciated, thank you
Unread 13-02-2014, 18:34
Kevin Phan's Avatar
Kevin Phan Kevin Phan is offline
College Student
FRC #0357 (Royal Assault)
Kevin Phan will become famous soon enoughKevin Phan will become famous soon enough
Re: Break/Coast feature
The brake/coast feature is on the speed controller. There should be small pins sticking out with a clip that plugs in the the brake or coast part of the controller. Refer to you speed controller's manual online to find where it is.
Unread 13-02-2014, 18:39
I normally prefer my speed controllers to brake, rather then break.
If you are using CAN on the jaguars, you can set brake/coast through the CANJaguar class. See CANJaguar::ConfigNeutralMode. Otherwise, like Kevin said, use the jumpers on the Jaguar.
Unread 13-02-2014, 22:09
Steve Warner Steve Warner is offline
Controls / Programming
FRC #0234 (Cyber Blue)
Steve Warner is an unknown quantity at this point
On a Victor you can run a wire from the center of the three pins to a digital output. Switching the digital output will switch the Victor between brake and coast. I'm not sure if a Jaguar works the same way.
