I am currently having issues with the driver station. I run Linux on all my machines, so I'm running the driver station from a windows 7 VM in Virtualbox. Unfortunately, the driver station is failing to connect to the robot at all. FYI, I am running the VM network in NAT mode, BRIDGED IS NOT AN OPTION.
Mostly, my question is: How do you get the driver station to work through a nat? |
Re: Using the driver station in a virtual machine
Why is bridged not an option?
The DS uses UDP for all communication and ICMP for diagnostic pings. The dashboard, if using camera or smart dashboard will use TCP as well.
If your NAT'd address is routable to the subnet of the DS and robot, I'd imagine this will work. But NAT implementations vary quite a lot and you are rather customized here. I hope this isn't what you were going to use for your competition DS. Greg McKaskle |
