Go to Post "Greatness isn't achieved by doing the uncommon things but instead by doing the common things uncommonly well." - Wayne C. [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 12-02-2014, 17:25
Ikillee Ikillee is offline
FRC #4733
Ikillee is an unknown quantity at this point
Second layer
Our second layer mounting on top of the first layer is going to be made of 1/2" thick plexiglass. The mentors are saying we should just go ahead with it. Is this going to be a problem?
Unread 12-02-2014, 17:29
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Second layer
Could you post images or better describe your situation? I'm not exactly sure what you're asking.
Unread 12-02-2014, 17:33
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Second layer
For general robot applications, ensure the "plexiglass" is polycarbonate and not acrylic.
Unread 12-02-2014, 18:55
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Second layer
The reason for this STRONG recommendation is that acrylic plexiglass very easily shatters. Many teams have used acrylic plexiglass, but they almost always use it just once, then they learn.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 12-02-2014, 19:45
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Second layer
I'm sorry: Did you say 1/2"? as in 0.5 inches thick?
Goodness that's overkill, way too thick for anything I can think of. I think the thickest POLYCARBONATE (not acrylic! Never!) we use is just under 3/16, and that's a major structural element of the robot.
Print this thread out and show it to your mentors. We're sure it is overkill.
Oh, and not plexiglass. Not ever. Even 1/2" thick.
Unread 13-02-2014, 17:28
FRC #4733
It's confirmed that we have acrylic plexiglass. We used a dremel on it and had some minor hallucinations from the smell. It's a half inch thick. I don't think we have a chance on getting a substitute for it by bag and tag day. We'll probably be practicing with for a bit and get a copy of it with polycarbonate by our regional.
Unread 13-02-2014, 17:32
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Second layer
I don't know exactly what you're using it for, but is there any possibility you could use plywood instead?
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 13-02-2014, 19:19
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Second layer
Probably a good idea. Two things:
Lexan is very strong, and it bends instead of breaking. 1/8" lexan is about as strong as 1/16" aluminum. So you could not possibly need Lexan thicker than 1/4".
Also, take careful notes on that piece of plastic, so you can pre-drill and cut things, making it an easy retrofit at competition.
Unread 13-02-2014, 20:16
Re: Second layer
I can think of something. Though even then it was only 1/4". http://www.chiefdelphi.com/media/photos/21476
Oh, and we were thinking of using plexiglass (or rather, "unidentified clear plastic") on the robot this year. A quick "smack! test" from a mentor left several pieces on the floor, and we found something else right away.
Unread 13-02-2014, 20:41
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Re: Second layer
Amazon.com is an good source of small sheets of polycarbonate. Much of it ships Prime.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 14-02-2014, 10:46
pfreivald's Avatar
AKA: Patrick Freivald
Re: Second layer
You can buy Lexan/polycarbonate on McMaster-Carr and ship it next-day air, too....
But at this stage in the game, I'd much rather use thin plywood than thick acrylic plexiglass. Plexiglass is a "no, no, no, no, never, never, NEVER" item in our workshop. Acrylic plexiglass shatters easily when subjected to FRC-level forces. .5" wouldn't give me the slightest bit of reassurance over .25".
Lexan good. Plexiglass bad.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 14-02-2014, 11:04
Racer26 Racer26 is offline
Re: Second layer
Heh. 1075 built our electronics on a plexiglass panel in our rookie year. That was the last time plexiglass ever made an appearance on a 1075 bot.
Unread 14-02-2014, 11:31
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Re: Second layer
Home Depot usually stocks a good selection of both acrylic and polycarbonate (lexan) in their windows section if you need something fast. Yes acrylic will shatter but with a piece 1/2" thick it's going to take an aweful lot of force. If you have the weight allowance I would say go for it if you have it in stock. If not, home depot for lexan/polycarb.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 14-02-2014, 12:10
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: Second layer
It is not clear to me what application you are using this for. It sounds like an outside layer of something that you would want to see through, so the suggestions here of lexan are good. We use 1/8" for side panels all the time. It will bend a lot in impact but rarely breaks, and when it does break it doesn't shatter.
If you don't need to see through it, corrugated plastic is a nice alternative as well. We often use 1/2" corrugated and it is light, sturdy stuff. We had a slide made of it last year that stuck out about 13 inches past its attachment on the frame members. You could whack that extension with a hammer and not do any significant damage.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 14-02-2014, 21:54
FRC #4733
So the acrylic broke today when one our members tried dremmeling hacksawing and hammering it to get it the right shape. It's all for the good now because we bought half inch plywood which is much lighter. We'll get us some lexan or polycarbonate and trace around the plywood after the deadline. Our second layer on top of the electronics needs to be clear so that the inspectors can see our circuit board. Thanks for the help!
