Go to Post ... Imagine NOT being able to count on certain things to stay the same from year to year... It makes you wonder what sort of sick, twisted mind would do such a thing to all those innocent teams out there... - dlavery [more]
Unread 13-02-2014, 18:58
kd8rgp's Avatar
kd8rgp kd8rgp is offline
AKA: Alec Hitchiner
FRC #1076 (PiHi Samurai)
kd8rgp is an unknown quantity at this point
Angry Using the driver station in a virtual machine
I am currently having issues with the driver station. I run Linux on all my machines, so I'm running the driver station from a windows 7 VM in Virtualbox. Unfortunately, the driver station is failing to connect to the robot at all. FYI, I am running the VM network in NAT mode, BRIDGED IS NOT AN OPTION.
Mostly, my question is: How do you get the driver station to work through a nat?
Unread 13-02-2014, 19:31
irvingc irvingc is offline
FRC #0948 (Newport Robotics Group)
irvingc is on a distinguished road
Re: Using the driver station in a virtual machine
You probably can't. The driver station and robot are supposed to be on the same subnet. You might be able to get a 255.255.255.252 subnet mask to work with some wonky NAT settings (robot is 10.XX.XX.2 -> 10.XX.XX.0/30, and DS is .5 or .6 -> 10.XX.XX.4/30), but getting the network configuration just right seems like much more trouble than running it through Wine, finding another laptop (any old laptop will do), or dual-booting.
Unread 13-02-2014, 19:33
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Why is bridged not an option?
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 13-02-2014, 20:06
kd8rgp's Avatar
AKA: Alec Hitchiner
Kernel Issues
Unread 14-02-2014, 09:10
The DS uses UDP for all communication and ICMP for diagnostic pings. The dashboard, if using camera or smart dashboard will use TCP as well.
If your NAT'd address is routable to the subnet of the DS and robot, I'd imagine this will work. But NAT implementations vary quite a lot and you are rather customized here. I hope this isn't what you were going to use for your competition DS.
Greg McKaskle
