Go to Post Hey, I'm not my dad, I dont know anything! - Lil' Lavery [more]
Unread 13-02-2014, 21:50
SgtMartian's Avatar
SgtMartian SgtMartian is offline
Sam Hassall
FRC #1075 (Sinclair Sprockets)
Team Role: CAD
SgtMartian is an unknown quantity at this point
Need help measuring RPM with the american Digital E4P-250 encoders
My team is using Omni drive for the first time in years, and none of the current members have used it before. Our robot does not want to drive straight and we can't get all the wheels to spin at the same speed. We've done swerve drive in the past, so we've used encoders, but using them for RPM is confuzzling our programmer.
Whenever we give it a command for all the wheels to spin at the same speed in a strafing configuration, it slowly veers away, or simply goes nowhere near where we want it to. We managed to solve this problem when we just set the motor speeds to constants to move it in its different directions, however they were like .5,.6, and .8. They had to be very different. We don't even have rotational control set up yet. Everything else on the 'bot is good though.
We're trying to check the output shaft speeds to make sure that they are all the same using the boston Digital E4P-250.
We don't think the problem is mechanical, so can anyone enlighten me on how to fix the problem? I think it is a combo of just checking the motor speeds and weight distribution.
pls halp.
Unread 13-02-2014, 23:26
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
Re: Need help measuring RPM with the american Digital E4P-250 encoders
You could try adding a gyroscope to help with driving straight.
If gyro_error > 0
 motors_right++
If gyro_error < 0
 motors_left++
If motors_left + motors_right > desired_speed
 all motors--
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 14-02-2014, 01:29
If you've used encoders for position before, using them for velocity is a simple as replacing the call to getDistance() with a call to getRate().
