Go to Post if we aren't here for some wisdom...what are we here for? - Molten [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 16-02-2003, 01:47
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Exclamation FESTO Help ASAP!!!!
Oh man....we are stuck in a bind with this FESTO!!!!!
From what i see we arent the only ones that are having problems. What should we do?!
Purdue Alumni
Cummins, Inc.
Unread 16-02-2003, 01:57
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Hmmm
This is a tough one...
We worked on this until about 1:00am Sunday morning...
The leadscrew is grounded and plugged in correctly,
we've got red 10 gauge wire to the exhaust port,
there's two wing nuts on top... just like the manual says.
Man... I don't know... I kinda feel like Austin there, who is so frustrated that he is crying over the robot.
We really need help on this... any other ideas?
Andy B.
ps... nooo, Clark, you can't take the RotoZip to the Festo Valve!
Unread 16-02-2003, 01:59
D.J. Fluck
Posts: n/a
Re: Hmmm
Andy B.
I'm currently reading the manual and spec sheet on the Festo Valve, and all I can say is that I am stumped beyond belief...
Unread 16-02-2003, 03:15
Guys,
It is now 2:00 AM and we have been working on the same thing. We discovered that 10 AWG is not rated for 60 PSI, try #6. Can you bring your robot to our shop and we can work on this problem together? The gangs all here!
Unread 16-02-2003, 11:47
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Didn't you guys read team update #42? It specifically states that you need to install a Magnetic Field Alignment Device (MFAD) in order to keep the solenoid aligned with the magnetic field of the Earth. Basically, it is a device that will continually rotate the valve so that the Magnetic Field from the Earth doesn't interfere with the operation of the magnetic solenoid. See attached picture for one such device that I found. Note, however, that you must use the "H" variety of MFAD as the "G" variety is specifically outlawed by the part-use flowchart.
Also, according to team update #74, you no longer need to ship the MFADs with the robot.
Unread 16-02-2003, 11:56
Oh the problems....
Oh man....those MFAD's are really hard to get a hold of. Delphi only uses the "D" variety and our local Wal-Mart is out of both the "H" and the "G" variety. Need more help!
Purdue Alumni
Cummins, Inc.
Unread 16-02-2003, 12:21
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
I have one for sale, if anybody needs a MFAD. Its a bit bigger then the newer models, but its going cheap:
http://www.pubarso.com/misc/izzy.jpg
Brandon Martus
e-mail
Unread 16-02-2003, 12:32
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Originally posted by Al Skierkiewicz
Guys,
After working all night and well into the morning, we gave up and decided to fix it in software.
Unread 16-02-2003, 14:07
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Thank goodness we can always fix any problem in software!
Unread 16-02-2003, 19:04
A. Snodgrass A. Snodgrass is offline
AKA: Ashlee Snodgrass
A. Snodgrass is a splendid one to beholdA. Snodgrass is a splendid one to beholdA. Snodgrass is a splendid one to beholdA. Snodgrass is a splendid one to beholdA. Snodgrass is a splendid one to beholdA. Snodgrass is a splendid one to beholdA. Snodgrass is a splendid one to behold
Didnt team 190 have a "g" type two years ago at their pit?
Ashlee Snodgrass
Hawai'i Regional Planning Committee and Alumni of Team 360 (2000 and 2001)
Unread 17-02-2003, 01:17
D.J. Fluck
Posts: n/a
Im pretty sure it was a "g" type...It was in a cage next to their pit at the 2001 Indiana Robotics Invitational.
2003 IRI is July 18th and 19th, sign up for it!
had to get that in there somehow
Unread 17-02-2003, 07:18
Clark, Andy and DJ,
We are still waiting on the software fix but we don't have an answer just yet, so we are still pursuing the hardware route. Something keeps buzzing around in my head but I can't grasp it. Something about grounding the lead screw just doesn't seem right.....
Unread 18-02-2003, 21:06
CNCBoy461's Avatar
CNCBoy461 CNCBoy461 is offline
Spaz
AKA: Matt
#0461 (WBI (Westside Boiler Invasion))
CNCBoy461 is an unknown quantity at this point
Send a message via AIM to CNCBoy461
Lightbulb Oooo, Thats A Tough One...
Man Oh Man! We Grounded Part Of Our Electronics To Our Frame Too! We Were In The Beta Phase, And An Extra Ground Wire That Was Going To Be Used For A Fan, And Yeah, I Plugged In The Battery, Flipped The Breaker, And ZAP! BLARGH Did That Hurt. Masochist I Am... Good Luck With All Of This!
P.S. Colors On Wire Is Irrelevant! Red To Black!
WBI Team 461
Let's All Go Nuts!
ROBOTS! ROBOTS!
CNC Master...6061, the prefered metal of choice
Unread 26-04-2003, 23:22
Austin's Avatar
Austin Austin is offline
Go TechnoKats!
FRC #0045 (TechnoKats Robotics Team)
Austin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to all
Send a message via AIM to Austin
Well, all-
We never got this to work, so we just decided to scrap it. I'm glad that we made that critical decision before pittsburgh, i don't know if we would have had time to fix it then! ahhh!
Austin Butler| Mac Addict | Purdue AAE | President, Sigma Gamma Tau | ENS USN/Student Naval Aviator
2002-2005 driver | 2004 Lead Mechanical | 2004-2005 Co-Student Leader | TechnoKats Robotics Team 45
Need a gearbox? Omniwheels? Check out AndyMark.biz
Unread 28-04-2003, 08:40
well, if you figure it out for next year, be sure to let us know
Q&A Discuss: FESTO Help ASAP!!!! CD47-Bot Extra Discussion 3 16-02-2003 10:55
Festo valve.... why wont it work? CHSguard72 Pneumatics 3 08-02-2003 19:07
Course Curriculum for A First Class, Please Respond ASAP archiver 2001 0 24-06-2002 01:33
Festo Valve Gary Bonner Pneumatics 2 26-02-2002 17:48
What is the wiring for the FESTO valve? Nuts4FIRST Technical Discussion 4 12-02-2002 17:14
