Go to Post Maybe it just seemed like five hours...I had freshmen in my vehicle! - Qbot2640 [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 13-02-2014, 10:36
Andrew Lawrence
Posts: n/a
Re: pic: Team 192's 2014 Gearbox
Originally Posted by DampRobot View Post
I believe they at least partially develop thse gearboxes in the fall.
Champions are made in the offseason.
Unread 13-02-2014, 13:19
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
What size belts and pulleys did you use? Have you seen any issues with the belts so far?
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 13-02-2014, 13:55
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
Over the past few years, prototypes have been built in the fall to test the new ideas and designs that are part of each gearbox. This has been very important because over the last three years the gearboxes have used untried and unproven concepts. The construction techniques and gear choices of the worm and bevel gearboxes were new and needed to be proven to work before we could decide to use them duing the season. This year the main thing that needed to be proven was the redesigned ball shifting shaft. We liked the ball shifting concept but thought the vex design could be improved. This design has as single piece output shaft, and use open bearings in the gears instead of the bushings.
The belts are 9mm wide, 3mm pitch Gates GT2 belts. The pulleys on this gearbox are 20T aluminum and 48T nylon filled ABS. I don't know how they're preforming on this gearbox so far but we used the same belts on last years drive gearbox, shooter gearbox, and the prototype for this gearbox with no problems when the belts are tensioned.
Unread 13-02-2014, 13:58
AdamHeard's Avatar
Lead Mentor
You'll be happy with the belts in that application. They're plenty strong.
Hard to say how I feel about the engagement on the two CIM belt though.
Unread 13-02-2014, 14:07
Joey Milia's Avatar
FRC #0192 (GRT)
Yeah, I expect no problems with the strength of the belts.
The prototype used 16T pulleys and an idler to get proper tooth engagement. That was stepped up to 20T to hopefully make an idler unnecessary and still have enough engagement.
Unread 13-02-2014, 22:39
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
This gearbox is simply gorgeous! Really love how it looks, obviously... but it certainly looks like it's filled with so much design!
I assume it's just the two stages, given the space on the gearbox and your speeds (19.5 and 8.5 fps)? Are those numbers theoretical, adjusted, or actual? I'm curious how you find the 3 CIMs combined with such high gearing... Seems like - especially for a full weight robot - that could be very battery-intensive.
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 13-02-2014, 23:11
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
Those are the speeds adjusted by a .85 speed loss constant, as for the battery drain: our robot is looking to be 75 to 90 pounds so the loading is appropriately scaled down.
Unread 14-02-2014, 12:37
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
This is beautiful, and it is a great example of my biggest problem with FIRST material usage rules. You can buy a gearbox that is developed and built specifically for FRC in the offseason, test it any way you want, and then use it without restriction. If you design and build one yourself, you can't (without restrictions). It definitely does not inspire teams to do what you did. Excellent work!
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 24-03-2014, 03:18
lukedude43 lukedude43 is offline
Doer of stuff and things
AKA: Luke Reinert
FRC #4030 (NullPointerException)
lukedude43 will become famous soon enoughlukedude43 will become famous soon enough
Hey, I really like how you used the pulleys as the first reduction off the cims. I found what I think are the same pulleys and they seem to have 2 8-32 set screws. Did you guys just crank one of the set screws into the keyway of the cim, and if so how has that been working out for you?
Unread 24-03-2014, 12:44
FRC #0192 (GRT)
The pulleys are manufactured with two M3x.5 set screws, we then drill the bore out to 8mm and broach a 2mm square key way and use that to transfer torque.
Unread 24-03-2014, 16:17
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Of course it's fabulous. I remember strolling over to your pit with our captain at Champs last year while you guys were gone to a match. We ended up marveling at the spare transmission you had on display for about a half hour and talking to a pit crew member about it. That's still the most amazed I've ever been by seeing an FRC robot part in person. This year, it looks like you've stepped it up again, and I commend your efforts. There might not be another team that condenses so much art into a transmission year in and year out.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 24-03-2014, 17:10
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Originally Posted by Rauhul Varma View Post
That sure is purty. Did you consider using a double sided belt (http://sdp-si.com/ss/pdf/80502117.pdf) and running it around all three motors in a serpentine path? (You would also have to relocate the motors a bit). That would let you get rid of some of the overhang, and flatten the gearbox width a bit. That said, it's pretty compact as-is. How did it perform?
Unread 25-03-2014, 01:26
FRC #0192 (GRT)
Originally Posted by nuclearnerd View Post
Did you consider using a double sided belt and running it around all three motors in a serpentine path?
When I was creating initial sketches of the gearbox, I played with using double sided belts but found that I would need multiple idlers to achieve proper tooth engagement on the cims and that a double sided belt would actually lead to a larger gearbox with more empty space inside it. I decided that the marginally lower CoG due to that type of motor placement did not outweigh a smaller gearbox with little to no dead space.
How did it perform?
As for the performance of the gearbox, we have not had to replace anything on them after 2 regionals and the drive base (the robot with the upper structure unbolted), as a whole, is operating around 53-58 dB.
Unread 05-04-2014, 22:30
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
Our gearbox won the Excellence in Engineering Award at the three Regional's that we went to this year.
KF6UZX
Unread 09-04-2014, 21:39
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Hi,
I was wondering what the weight of this gearbox was? Did you cheesehole any of the gears?
