Go to Post Come on baby, do the logomotion with me. - JaneYoung [more]
Unread 13-02-2014, 23:01
Diplodicus Diplodicus is offline
FRC #1339
Diplodicus is an unknown quantity at this point
Having trouble with Talons
We are running a 6 CIM drive base each controlled with Talons. For some reasons two of the talons are outputting slightly less voltage. I have checked the input voltage on the talons from the power distribution board and the voltage on the PWM cable and they match the voltage going to the other talons. We have replaced the talons themselves twice and it is still a problem with the location. Does anyone have any idea what the source of the problem is?
Unread 13-02-2014, 23:09
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Having trouble with Talons
Have you calibrated the Talons?
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 13-02-2014, 23:17
FRC #1339
I don't know what your talking about but the problem isn't with the talons themselves because we have replaced the with Talons we have confirmed to work in other locations.
Unread 13-02-2014, 23:19
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Actually the problem itself might be the Talons...Have you calibrated them??
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 13-02-2014, 23:21
FRC #1339
What do you mean by calibrating? I have never heard of calibrating Talons.
Unread 13-02-2014, 23:24
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Secrets like this are often kept in the manual.
http://www.crosstheroadelectronics.c...Manual_1_1.pdf
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 13-02-2014, 23:25
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Voltage drops with longer wires. The effect isn't huge (on the order of 10ths of a volt, based on this calculator) on an FRC robot scale, but it may explain your problem. Are the problematic Talons farther from the PD board than the others?
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Chris_Ely's Avatar
AKA: luckof13
See page 7 of this manual.
Calibrating sets the Talon output to follow the PWM signal. So full is full, and neutral is neutral.
Unread 13-02-2014, 23:28
FRC #1339
The only thing that is different is that the voltage drop over the two Talons is .24 volts and the voltage drop over all the other talons is 0 volts. The resistance across the positive leads is also higher than the other talons which have a resistance of close to 0.
Unread 13-02-2014, 23:29
FRC #1339
Broken link
Unread 13-02-2014, 23:31
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Broken link
Unread 13-02-2014, 23:34
What do you mean by voltage drop "over" the Talons? And resistance "across the positive leads" ? Could you post a quick sketch?
Unread 13-02-2014, 23:35
Chris_Ely's Avatar
AKA: luckof13
Broken link
Works for me.
Try one of the many other links in this thread.
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Smile Re: Having trouble with Talons
Diplodocus says to tell you thank you, and that the calibration worked.
