Go to Post There will be violence next year! YAY! - Koko Ed [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 14-02-2014, 01:16
Ikillee Ikillee is offline
FRC #4733
Ikillee is an unknown quantity at this point
Basically what I'm asking is if it's hard to mount a second set of motors to the drive train.
Unread 14-02-2014, 01:22
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: Second set of motors
No it's not that hard. Are you guys using the KOP drive system
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 14-02-2014, 02:11
nicholsjj's Avatar
nicholsjj nicholsjj is offline
AKA: John Nichols
no team (Devil Bots)
nicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant future
It's not that hard at all if your team keeps track of its spare parts. You will need four bolts to mount the motors to the other motor mount port on the gearbox, our team also uses thread locker on them. You will want to attach a CIM shaft output gear with the keyway and retaining clips on the CIM motor before you attach it to the gearbox. Make sure you are using the same tooth count as your other CIM gear that is already mounted. You then will need to add two more motor controllers to your electronics board. You do not have to change programming at all if you are using tank drive. You will however need to change your pwm cable to a Y-pwm cable and plug those outputs into both the already used controller and the newly placed controller. Also pay attention that doing this doesn't add to many CIM motors to your robot total, 6 large CIMs total are the max. This also adds a higher current draw for your drive but it is usually a good choice IMO due to acceleration being increased.
2011-FRC Team 3862, Team Captain
2012-FRC Team 3862, Strategy Mentor
2013-FRC Team 3885, Programming Mentor, Razorback Regional, Curie Inspector
2014- FRC Team 3885, Programming Mentor, Arkansas Regional, Newton inspector
2015-??? Teacher Murphysboro High School
“They call it coaching but it is teaching. You do not just tell them…you show them the reasons.”- V. Lombardi
