Re: Stopping an Axis-Controlled Motor
Going along what Mark said, you could try wiring a button in-between the axis and the MotorSet block. When the button is pushed (true), the MotorSet block would recieve the joystick value but otherwise (false) it is set to zero.
If the joystick isn't setting the motor back to zero like it's supposed to, this would guarantee a total stop because of the button override. Is that the problem you're having? |
