Go to Post Someone once said, "I know what finished is, and I know what a robot is, but what is this finished robot you speak of?" - EricH [more]
Unread 14-02-2014, 10:53
18mfogwell's Avatar
18mfogwell 18mfogwell is offline
AKA: Michelle Fogwell
FRC #4460 (Green MASHine)
18mfogwell is an unknown quantity at this point
Wifi name changed?
We rebooted our robot and the wifi name of the bridge changed from "4460" to "4460 2". We didn't change any of the wifi settings. Why/how could the name possibly have changed?
Unread 14-02-2014, 11:00
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Re: Wifi name changed?
I don't know the exact reason for this issue, but I've had it before and never had an actual issue on the 'XXXX 2' network.
If I'm not mistaken, on my home WiFi network (not a D-link router though), there's a '(wifi name) 2' network that is transmitting at 5 ghz as opposed to 2.4
Unread 14-02-2014, 11:02
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
The only thing I can think of is were you running two routers with the same name? It may default one of them to 2...either way, an odd error and I'd say re-image your d-link for starters.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 14-02-2014, 11:09
18mfogwell's Avatar
Okay i will try this.
Another problem i found was that on DS its says, "Watchdog not fed". What does this mean?
Unread 14-02-2014, 11:41
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
It's a windows networking affectation. Your network name has not actually changed.
Go into your wireless network manager and delete all the networks you have there. Then go back and refresh your networks and you will find that the '2' has been removed.
How many times did you see 'watchdog not fed'. Once is normal. Many times is bad.
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
Windows will do this when it sees two networks with the same name.
1. Go to "Network and Sharing Center"
2. under "View your active connections", click on the icon (bench, building, house...)
3. "Set network properties" dialog will appear
4. click "manage or delete network locations"
5. delete unneeded networks, or use merge .
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 14-02-2014, 13:39
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
TogetherSword8 is an unknown quantity at this point
There are two ways this happens, if the computer sees it across multiple bands (to check this, go to the router's page at its ip address and check there for what band it is using) or if you have multiple wireless cards in your computer. In our shop, we use two wireless cards on one computer (so we don't have to change our ip to access the internet or the robot), and our robot shows up on the two cards as 888 and 888 2. It is windows differentiating between networks and network cards.
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
