Go to Post You could mount a small Black Hole on the top of your bot, and park it in front of the center goal - that would work...just keep your human player away from the event horizon. - KenWittlief [more]
Unread 13-02-2014, 14:16
AIS Falcons's Avatar
AIS Falcons AIS Falcons is offline
FRC #4338
AIS Falcons is an unknown quantity at this point
Analog Sensors Returning Incorrect Voltages
Hey all,
Today we were adding our sensors to the robot and started testing out code and we discovered the they were returning near zero voltages from the getAverageVoltage() method.
[cRIO] Ultrasonic: -0.0014189800000000002
[cRIO] Potentiometer: 0.23009997599999998
[cRIO] Potentiometer: 0.24552717599999999
[cRIO] Potentiometer: 0.240384776
[cRIO] Potentiometer: 0.214672776
[cRIO] Potentiometer: 0.101539976
[cRIO] Potentiometer: 0.142679176
[cRIO] Potentiometer: 0.122109576
[cRIO] Potentiometer: 0.106682376
Does anyone have an idea as to why this is happening? We wired them right as far as we know and the Analog Breakout has power. We were also adjusting the sensors correctly.
Thanks for any help
Unread 13-02-2014, 14:19
Re: Analog Sensors Returning Incorrect Voltages
Are you sure you didn't plug them in backwards?
Unread 13-02-2014, 14:21
vgdude999 vgdude999 is offline
Programmer/Driver
FRC #1751 (Comsewogue Warriors)
vgdude999 is an unknown quantity at this point
I had a similar problem with an ultrasonic, but that was a few weeks ago and I forget exactly how I fixed it. I think I had some code in the wrong place... It might help if you posted your code so we could take a look at it.
2013: Rookie year, programmer-in-training; SBPLI Regional Finalists
2014: Co-Captain, Programmer, Driver; Seeded 15th
2015: Co-Captain, Programmer, Driver
Unread 14-02-2014, 11:06
FRC #4338
Thanks!
Our Analog Breakout seemed to be labeled wrong and the Potentiometer now works fine. However; the ultrasonic returns either a constant voltage of 3 with one orientation or a voltage ranging from 0-1. We are using the basic MaxSonar analog ultrasonic sensor.
Any information would be incredibly beneficial.
Thanks,
Team 4338
Unread 14-02-2014, 11:51
dvanvoorst dvanvoorst is offline
FRC #2771 (Code Red)
dvanvoorst is an unknown quantity at this point
I'm not sure about an analog ultrasonic sensor, but the digital ones require you to tell it when to ping. With the Ultrasonic object, you can turn on an "automatic mode" that will continuously ping.
us = new Ultrasonic(2,3);
us.setAutomaticMode(true);
Unread 14-02-2014, 12:03
FRC #4338
If I remember correctly ping isn't a factor in an analog object (correct me if I'm wrong). The analog channel class has no method for setting ping. We tested with a multimeter and the sensor was receiving 5 volts when ground and +5 were tested. The AN return a near 0 voltage as before. We are getting correct readings from the pot so I can only assume something is wrong with either the sensor itself or the signal wiring.
Thanks
Unread 14-02-2014, 13:40
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
Remember that the analog voltage is just proportional to the distance. Does it change with distance to the sensor?
I am assuming you are using the LV series sensor and have read the datasheet and the application notes for the sensor (I know because we screwed up at first too).
http://www.maxbotix.com/documents/MB1000_Datasheet.pdf
Enjoy!
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 15-02-2014, 06:31
FRC #4338
Thanks, we figured it out! The sensor is now working perfectly fine with further testing it should be great!
