Go to Post Everyone is reading way too much into this. The game piece is clearly a bunch of Opahs this year. Problem solved, case closed. Start designing your fish handling robots now. - Ryan Dognaux [more]
Unread 14-02-2014, 13:03
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
Java Commandbase Subsystems: Init vs DefaultCommand
Here is a question for all you Java types:
Which (if either) way is 'better' (less intensive on the cRIO, easier to understand, etc).
In a command based template we have a compressor subsystem.
We could start the compressor (using the standard compressor.start() method) in the subsystems initialization call. We could also just create a simple command that just does a compressor.start() in its execute function and then call this as the compressor subsystem's default command.
    public subcompressor(int compressorSwitchSlot, int compressorSpikeSlot) {
        myCompressor = new Compressor(compressorSwitchSlot, compressorSpikeSlot);
        LiveWindow.addActuator("compressor", "compressor", myCompressor);
        myCompressor.start();
or
     * Default command is to start the compressor.  Doing it this way instead
     * of in the initializer will put it in a separate thread and not lock the
     * main control thread.
    public void initDefaultCommand() {
        setDefaultCommand(new StartCompressor());
Is one way better then the other? Do both ways use separate threads from the main thread?
Just cleaning up code and wondering.
Thanks
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 14-02-2014, 13:07
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Java Commandbase Subsystems: Init vs DefaultCommand
or
Thanks
We actually just create and start the compressor either in RobotTemplate or in CommandBase. But neither of those will use separate threads, the Command Based structure uses a Scheduler that runs on a single thread to execute all of the commands.
Unread 14-02-2014, 13:13
This is the slightly less intensive option. It doesn't make the scheduler do anything extra.
They both use separate threads, because the Compressor class creates a separate thread.
Unread 14-02-2014, 13:14
Flywheel Police
Ahh, my fault.
