Go to Post A good way to minimize the possibility of breaking things is to minimize the number of things that can break. - s_forbes [more]
Unread 14-02-2014, 13:59
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Compressor gets hot and blows line
So when we enable the robot the compressor kicks on, the pressure builds in our high pressure tanks, gets to 65 psi, holds there for ~20 seconds, then the line coming out of the compressor blows out. The line and compressor are very hot when this happens. Any ideas?
Unread 14-02-2014, 14:07
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Re: Compressor gets hot and blows line
How much air storage to do have? And does the compressor have a fan on it? The VIAIR really needs one if it is going to be running for any extended period of time.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 14-02-2014, 14:11
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Compressors create heat when they compress air. In normal usage the heat is dissipated and doesn't cause a problem. If however the compressor is on for a long period of time, like in practice, there can be enough heat generated to soften the hose and create failure.
In good practice to connect the pressure relief valve and pressure switch directly to the compressor with brass fittings. This helps isolate the hose from the heat. The more metal between the hose and the compressor the better.
Unread 14-02-2014, 14:16
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
How many tanks, of what size, are you trying to fill?
To that end, note the compressor in the lower left-hand corner of the robot: coupler, tee to relief valve, couple, tee to pressure switch, couple, tee to pressure gauge, then the quick-disconnect to a hose.
We also added the medium-sized muffin fan from the KOP blowing across the compressor and fittings, which helps a lot.
Unread 14-02-2014, 14:18
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
We found that this happens as well. Mounting a 12V server fan pointed right at it keeps it as cool as a cucumber... or at least one that has been sitting on the counter. We had to run without the fan last night, and remembered just how hot it got.
Unread 14-02-2014, 14:26
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Not only is it good practice, but the relief valve is required to be teed to the compressor with a metal fitting by rule.
Unread 14-02-2014, 14:29
Does the tubing pull out of the compressor or does the line fail by producing a bubble and then blow out at the soft spot?
If it produces the bubble then the compressor is likely running continuous for several minutes (~10 or longer). It sounds like the high pressure relief valve is not calibrated. This is supplied uncalibrated and needs to be adjusted by the team to release at 125 psi. A compressor that runs for an extended period will blow out the line. It does this by heating the tubing to a temperature where it fails under pressure. To calibrate, loosen the locking ring on the valve, it is the lower hex hardware on the valve. Then power the robot and enable, short the pressure switch which should run the compressor continuously. With an accurate pressure gauge on the high pressure side, watch for the pressure to rise to 125 psi and listen and feel for air escaping the top of the valve. If it does not, turn the top counter clockwise until air is vented from the valve. If air is released at a lower pressure, then turn the top clockwise until 125 psi is reached when it vents. Tighten the locking ring without letting the top of the valve rotate. Remove the short across the pressure switch and see if the compressor shuts off when the pressure reaches ~120 psi.
If it simply pulls out of the fitting, one of two things are occurring. Your gauge is not accurate and you are exceeding 150 psi and failing at the fitting. Or the fitting could be bad and not securing the tubing. Once inserted you should not be able to pull out the tubing without pressing the release ring first.
Unread 14-02-2014, 14:31
Originally Posted by matthewdenny View Post
... the pressure builds in our high pressure tanks, gets to 65 psi, holds there for ~20 seconds ...
That sounds like your main regulator is not plumbed correctly.
On the regulator there is an arrow on one of the ports. The high pressure tubing must go into the port that is at the tail end of the arrow, and only that port. The other three ports are kept at working pressure ~60psi.
Unread 14-02-2014, 14:33
You're missing a few important pieces of information. How long is the compressor on when it's building pressure in your high pressure tanks? What gets to 65PSI, low pressure gauge or high pressure gauge? How much air storage do you have on the high pressure side?
I suspect you've mis-plumbed something or have a leak somewhere, causing the compressor to be on much longer then expected.
Unread 14-02-2014, 14:34
Mark I think has the solution. I did not consider the regulator in backward. It is designed to vent to atmosphere any excess pressure on the output port.
Unread 14-02-2014, 14:37
FRC #6054 (Dukes)
We are pressurizing 3 of the 41in^3 tanks.
The setup
VI Compressor-->Tanks (with pressure switch, and pressure gauge installed on the tanks -->Regulator (60 psi) ----Splits to two paths
Path A: ---> 30 psi regulator -->solenoids
Path B: ----> Solenoids
Unread 14-02-2014, 14:38
FRC #6054 (Dukes)
Let me check the regulators, and get back to you.
Unread 14-02-2014, 14:40
FRC #6054 (Dukes)
The high pressure side gets to 65 psi.
The compressor is on a minute or so, and gets to 65 psi, stays there, and half a min later or so blows the line.
~120 in^3 of air stored on te high side. No tanks after the main regulator.
Kyler Hagler's Avatar
Kyler Hagler Kyler Hagler is offline
Jack of all trades
Kyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura about
Like many have said, we always use lots of brass fittings at the beginning of the line from the compressor and put the required fittings on there as well, this helps because the brass dissipates the heat before it reaches the tubing.
Kyler Hagler - 3310 Alumni/Mentor
Black Hawk Robotics Team 3310
2012 Dallas West Regional Winner
2013 Dallas Regional Winner
2014 Colorado Regional Winner
2015 Hub City Regional Winner
2016 Arkansas Regional Winner
2016 Hub City Regional Winner
Http://Team3310.com
Unread 14-02-2014, 14:42
Nate Laverdure's Avatar
FRC #2363
Reverse the polarity to the compressor?
Originally Posted by Al Skierkiewicz
The compressor runs in either direction. It is more efficient in the proper direction so the opposite polarity gets it a little hotter than normal.
Originally Posted by Don Rotolo
Temporarily disconnect the compressor and use a voltmeter for testing. reverse polarity may make the compressor supremely unhappy.
