Go to Post The GDC is the Grinch because they just stole my Christmas! - scottmacdonald [more]
Unread 13-02-2014, 08:16
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
swwrobotics is an unknown quantity at this point
Does Versaplanetary Kit Include Everything?
Hey everyone, so our team is ordering an assembly for what would be a disassembled versaplanetary 12:1 ratio gearbox for a minicim with a 1/2" hex output shaft. We were wondering if the kit you buy comes with the input shaft gear for the minicim.
So if we were to make an order at http://www.vexrobotics.com/versaplanetary.html, would we be able to get everything we needed if we got the (1) Base VersaPlanetary 1:1 with 1/2" Hex Output (base kit), (2) VersaPlanetary 3:1 Gear Kit with Ring Gear and (3) VersaPlanetary 4:1 Gear Kit with Ring Gear? Also, any advice for finding mounting brackets of some kind for the gearbox?
Unread 13-02-2014, 08:24
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
Exclamation Re: Does Versaplanetary Kit Include Everything?
There is no standard way to mount a MiniCIM to a versaplanetary. However, Spectrum 3847 has an excellent manual on how to do this, found here on their blog.
As for having everything you need, the basekit plus the two (3:1 and 4:1) stages should be all you need for a 12:1 ratio. For mounting, there are some threaded holes on the gearbox itself that can be used to screw it onto whatever you are mounting to. We have been very satisfied with the versaplanetary gearboxes so far.
EDIT: I just realised that the screws for the gearbox and the MiniCIM are a little bit different, and is mentioned in the comments on the blog post. We use a different bottom for the gearbox that we machined which has the correct threads to mount to the motor. There may be other ways to get around this - I'm not sure.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Last edited by Calvin Hartley : 13-02-2014 at 08:27. Reason: sudden dawning of memory
Unread 13-02-2014, 10:10
DampRobot's Avatar
Physics Major
AKA: Roger Romani
You can use the screws included in the kit (yes, I know, the 8-32s) to mount the CIM. You'll need a short section of 2mm keyway, but you'll probably have that lying around anyway.
-Plutarch
Unread 13-02-2014, 11:07
Oh wow, I didn't even realize the size difference between the bag and minicim motors. We'll definitely account for that! And thanks for all the advice!
Unread 14-02-2014, 11:58
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
If you need a little more power there's a dual motor option for the Versaplantary. A couple of RS-775 18 volt motors do wonders.
Bolts right together an gives you the option of adding any gear ratio you wish.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 14-02-2014, 12:04
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
I thought CIMs (and MiniCIMs) used 10-32 for mounting?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 14-02-2014, 12:38
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
That's the thing. If I understand correctly what some people are doing, they use 8-32 screws to go through the 8-32 holes on the VersaPlanetary and into the 10-32 MiniCIM holes. The VersaPlanetary input block's hole pattern is on a slightly smaller circle than the MiniCIM mounting holes (1.95" vs 2.00"), which will serve to keep the screws a little tighter than they otherwise would be in a hole with the wrong thread size.
Unread 14-02-2014, 12:46
Aren_Hill's Avatar
Build Nifty Things
I much prefer drilling out the holes in the input block to a clearance for 10-32, and then either milling clearance for a 10-32 socket head, or grinding down the screw head diameter so it fits nicely.
8-32 screws in a 10-32 holes? no thanks
-Aren
(this is a personal recommendation only, not a VEXpro one)
A guy who likes robots.
Unread 14-02-2014, 14:47
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
-Aren
No arguments from me.
How easy or difficult is it to drill out those holes to 10-32 size, given that smaller holes are already there that are on a slightly different center? Drilling them out to a bigger size is easy, but moving the center of the hole sounds pretty tough to me. Disclaimer: I'm not exactly a genius when it comes to machining.
Unread 14-02-2014, 14:50
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
When we modded our VPs this year we drilled out the 2" hole spaced circles. Since the 1.95 spacing is designed to keep the VP together.
We also did what Aren suggested and shaved the #10-32 socket cap screw down. Works well.
R.C.
MadTown Robotics Team 1323
