Go to Post The GDC needs to write the rules once and let the game be what the game is going to be. There's little that's fun about being told exactly how to play with your toys. - Madison [more]
Unread 14-02-2014, 11:46
defcon4 defcon4 is offline
FRC #3340
defcon4 is an unknown quantity at this point
Watchdog Question
Hi...I was wondering if someone could help me out with Watchdog. We are using Java for the first time and everything seems to be going well. I have seen sample code around the net using the code getWatchdog in the simple robot template. I have not seen it used in the iterative robot template and that is what our team is using. We are using a mecanum drive system and pneumatics for the rest of our system. My question is do I have to use Watchdog in the iterative robot template and if so where and how do I code it. Thank you
Unread 14-02-2014, 11:47
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Watchdog Question
As far as I know, you don't have to worry about it.
Unread 14-02-2014, 14:06
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
The IterativeRobot class takes care of feeding the watchdog for you. You don't need to mess with it if you don't want to.
http://team2168.org/javadoc/src-html....html#line.145
My assumption is that SimpleRobot does something similar.
http://team2168.org
Unread 14-02-2014, 15:07
FRC #3340
Thank you that was very helpful.
Unread 14-02-2014, 15:38
The watchdog is disabled in RobotBase by default (both SimpleRobot and IterativeRobot extend RobotBase). SimpleRobot does not feed the watchdog in the background like IterativeRobot, because there is no background in SimpleRobot. If the user enables the watchdog in SimpleRobot, the user must also feed it.
Unread 14-02-2014, 19:56
FRC #3340
Awesome! Thanks!
Unread 25-02-2014, 08:14
Herbblood's Avatar
Herbblood Herbblood is offline
Knowledgeable
AKA: Ally
FRC #3044 (OxBE4)
Herbblood is an unknown quantity at this point
Just don't mess with watchdog, we've had problems with watchdog before and perfer not to use it.
Off to WPI!
Go OxBE4
