Go to Post Congratulations! You have been successful! You got what you wished for! Now get to work. - gblake [more]
Unread 14-02-2014, 15:54
octopirates3502 octopirates3502 is offline
FRC #3502
octopirates3502 is an unknown quantity at this point
Analog Declaration Preventing All Robot Functions
In the process of building the robot for the 2014 game, we decided to use a potentiometer to figure out what angle our shooter was angled at. However, whenever I declare anything that would be plugged into an analog port (searched "analog" on http://robotics.francisparker.org/javadoc/) it renders all functions on the robot useless, and I receive the error "Robots don't quit!" What could be happening?
Unread 14-02-2014, 15:56
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Analog Declaration Preventing All Robot Functions
Have you tried this class yet?
http://robotics.francisparker.org/ja...ntiometer.html
Unread 14-02-2014, 16:02
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
My initial guess is that an exception is being thrown by the declaration or use of something related to the analog input in code. Look up in the output from the "Robots don't quit" message and see if there is a stack trace or error message explaining what the problem is (and post it here if you can't figure it out ).
Unread 14-02-2014, 16:55
FRC #3502
This is it
[cRIO] [Squawk VM] Version: 2011 FRC, Nov 5 2011, 14:34:13
[cRIO] FPGA Hardware GUID: 0x1394f6dc1feb42ec6910e5767ed1d22c
[cRIO] FPGA Software GUID: 0xa14c11bde4bb64aef6a86fc52a294cd9
[cRIO] edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter@8 entered connection state: GOT_CONNECTION_FROM_CLIENT
[cRIO] edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter@8 entered connection state: CONNECTED_TO_CLIENT
[cRIO] edu.wpi.first.wpilibj.util.AllocationException: Analog channel 8 on module 1 is already allocated
[cRIO] at edu.wpi.first.wpilibj.AnalogChannel.<init>(AnalogC hannel.java:68)
[cRIO] at edu.wpi.first.wpilibj.AnalogChannel.<init>(AnalogC hannel.java:49)
[cRIO] at edu.wpi.first.wpilibj.templates.subsystems.Basket. <clinit>(Basket.java:27)
[cRIO] in virtual method #109 of com.sun.squawk.Klass(bci=49)
[cRIO] in virtual method #106 of com.sun.squawk.Klass(bci=328)
[cRIO] in virtual method #105 of com.sun.squawk.Klass(bci=32)
[cRIO] in static method #25 of com.sun.squawk.VM(bci=4)
[cRIO] at edu.wpi.first.wpilibj.templates.commands.CommandBa se.<clinit>(CommandBase.java:20)
[cRIO] in virtual method #106 of com.sun.squawk.Klass(bci=156)
[cRIO] at edu.wpi.first.wpilibj.templates.RobotTemplate.robo tInit(RobotTemplate.java:35)
[cRIO] at edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72)
[cRIO] at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase .java:235)
[cRIO] in virtual method #10 of javax.microedition.midlet.MIDlet(bci=17)
[cRIO] at javax.microedition.midlet.MIDletTunnelImpl.callSta rtApp(64)
[cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(110)
[cRIO] in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO] at com.sun.squawk.Isolate.run(1506)
[cRIO] at java.lang.Thread.run(231)
[cRIO] in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO] in static method #3 of com.sun.squawk.VM(bci=6)
[cRIO] java.lang.Error: ExceptionInInitializer: edu.wpi.first.wpilibj.templates.subsystems.Basket: edu.wpi.first.wpilibj.util.AllocationException: Analog channel 8 on module 1 is already allocated
[cRIO] in virtual method #106 of com.sun.squawk.Klass(bci=409)
[cRIO] WARNING: Robots don't quit!
[cRIO] ---> The startCompetition() method (or methods called by it) should have handled the exception above.
[cRIO] task 0xca7f88 (worker.0) deleted: errno=0 (0) status=0 (0)
Unread 14-02-2014, 16:57
FRC #3502
Originally Posted by notmattlythgoe View Post
yes, we did try that class. In the end, we settled to try the AnalogChannel class. In the code we have:
private static final AnalogChannel pot = new AnalogChannel(8);
but it just doesn't like the declaration
Unread 14-02-2014, 17:02
dvanvoorst dvanvoorst is offline
FRC #2771 (Code Red)
dvanvoorst is an unknown quantity at this point
In the middle of your diagnostic message, you'll see that it believes analog port 8 is already being used:
Try using a different port.
Unread 14-02-2014, 17:23
FRC #3502
It worked, thank you so much!
Unread 14-02-2014, 18:06
Port 8 is used to read the battery voltage.
